Test Pipe for Cat
Old May 1, 2007 | 03:07 PM
mvftw's Avatar
Test Pipe for Cat
Is there a source to get a test pipe to take the place of the Cat? Or do I have to get a custom made one?
Old May 1, 2007 | 04:10 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Test Pipe for Cat
You can just go to an aut parts store and piece together some piping. I would rather take it to a shop and get a pipe put in. I had a straight pipe put in place of my cat and my car sounds so much better.
Old May 1, 2007 | 05:22 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
it violates federal law for an exhaust shoppe to do this on a street car. that being said, many shoppes will still do it. realy what you aught to do is look under your car and check to see that both sides of your catalitic converter have flanges, if it does go buy some, buy some pipe, measure and cut. take pipe to shoppe and have them weld it for you (or weld it yourself if you have welder) then go home and bolt it in.
if you do not have flanges you need to find a dishonest shoppe to weld one in for you. or just keep the cat. they only affect anything if they are old or clogged. i replaced mine with a new high flow (weighed about 1/3rd as much) and did not affect sound at all. plus now i am not breaking the law. the cat cost 20$ installation with flanges on both sides was another 30ish.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
