Vaccum Resevoir
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Vaccum Resevoir
As some of you know I have been having a idle problem for a while and can't seem to find it. I have replaced/fixed many small things that have helped. I was wondering if I get a vaccum resevoir if that will help with my idle/vaccum problem. I know that it won't fix the leak but it will at least help make my problem diminish. This will be a temporary solution until I rebuild another motor to put in my car. Could getting one help any?
Another thought I had is that could I have an aftermarket cam that I don't know about even though it is highly unlikely?
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Vaccum Resevoir
Nope, all the resevoir does is store vacuum for the cruise control and HVAC, it won't help your idle problem.
87FormulaGuy
Mar 21, 2001 10:55 PM
Zepher
Jan 15, 2001 02:29 AM
