transaxle
Old May 11, 2007 | 11:11 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
transaxle
there was some talk about taking other gm transaxle motors and coverting them to be rear wheel drive engines. i was just wondering how hard it is to do. and if its even worthwhile
Old May 12, 2007 | 09:21 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: transaxle
IMO , it's generally not worth it unless you are willing to have a lot of install issues, but end up with something that is definitly unique. There's harnesses, starters, transmissions, driveshafts, motor mounts, hoses, sensors and all the other stuff thatgoes into it with a lot of planning and test fitting.
If all you're looking for is more power, do an engine upgrade to something that's already rear drive, preferably a motor that was available in the fbody at some point (660, small block-based motors), but that's all my personal opinion.
Old May 13, 2007 | 05:07 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
Re: transaxle
yeah thats what i was afraid of. i was thinking about trying to find a rebuild of the 3.8L turbo they put in the ttA and the buick grand nationals, but i'll might just end up going with the 3.1 again because i need an engine soon because the last one had a piston rod break and just tore up the engine.
Old May 14, 2007 | 09:11 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: transaxle
3.4 upgrade man, best bang for the buck, and easiest. do a search for it and youll find all kinds of stuff. plus check out the write up by KED85 in the tech articles. He did an amazing job on that.
82Camaroguy
Fabrication
133
Mar 6, 2016 06:23 AM
ez2cdave
Aug 2, 2013 11:53 AM
The_Punisher454
Dec 9, 2010 01:40 PM
ian1320
Jul 30, 2009 06:33 AM
ModPog84z28
Apr 11, 2009 07:38 PM
