Replacing timing cover gasket
Old May 15, 2007 | 08:00 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I am replacing my timing cover gasket. Is there anything else I should replace. I was thinking of replacing the timing chain. I 'm not sure if it has ever been replaced.
Also my car vibrates real bad at idle. My car is idling at ~1100 and I know where my vaccum leak is at. Everything vibrates and I was wondering if it is the harmonic balancer?
Old May 15, 2007 | 08:34 PM
pairtoe's Avatar
Re: Replacing timing cover gasket
replace the timming chain and both sprokets, your gonna need a puller to remove the crank sproket. and when you put it back on get a striaght edge and line the two dots up perfect with the new chain back on. otherwise you will never get your timming right.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
