twin turbo headers now available
mild steel
room for 2.5 inch down pipes down each side of the engine
can be ceramic coated for an additional cost
setup for internally wastegated turbos,can add external wastegate flanges for an extra 50$'s
headers are fkanged for t3/ t3/t4 turbos
passenger side header routes under the alt bracket and requires removal of smogpump/or idler pulley
driver side header requires removal of ac compressor, header routes over top of ps pump
375$'s a set uncoated
pics to be posted later tongiht
also available in 316L stainless, for 900$'s a set
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: twin turbo headers now available
jeez dave, you are pretty much an animal in the v-6 fabrication world.. good job
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Need to get some pics posted of them alone and installed.
Don't hafta be a complete install set up pic just the headers on so folks get a better idea of how they route and will look.
You can explain it all day but seeing works better.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I'm going single turbo, so I'll need the drivers side turbo ready header, along with a regular header on the passenger side. Need a custom Y-Pipe as well. Can you have them ready by 3:00 o'clock today, eastern standard time.....?
j/k
... but I do need them asap, well, you already know why!
j/k... but I do need them asap, well, you already know why!
Originally Posted by daves12secV6
mild steel, room for 2.5 inch down pipes down each side of the engine, can be ceramic coated for an additional cost
setup for internally wastegated turbos,can add external wastegate flanges for an extra 50$'s, headers are fkanged for t3/ t3/t4 turbos, passenger side header routes under the alt bracket and requires removal of smogpump/or idler pulley, driver side header requires removal of ac compressor, header routes over top of ps pump, 375$'s a set uncoated, pics to be posted later tongiht, also available in 316L stainless, for 900$'s a set....
j/k
Last edited by daves12secV6; May 24, 2007 at 10:50 AM. Reason: Automerged Doublepost
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
