v6 headers installed, now runs horrible
Re: v6 headers installed, now runs horrible
Thats not the prob. The IAT sensor is brand new and its screwed in..the CAI had an opening for it right behind the filter. Cannot see it in the pics from that angle.
MAP sensors are expensive. Hope it not that... Summit has it for $80.00
Can it be unplugged to test if it is the problem or is that ill advised? What about the EGR? Unplug it? yes..no?
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Tantrum? I fully understand electronics and I don't care how many people say that the sensor won't read correctly. Extending a voltage based wire should not change the ouput if correctly connected as 2.8boy said.
My statement was directed at your thoughts about the mechanic...
Not this...
Not this...
if just rather the only thing I could think of what was going through the mechanics mind which I say is wrong just like you.thank you for taking my comments without getting pissy. I'm in a good mood and this is just the way I am. like to give people crap. and the tantrum part came from the sound of frustration with the added ?!?!?!?!?! on the end. just sounded
ish.
god someone needs to
me Re: v6 headers installed, now runs horrible
hey never said the mechanic was right
ish.
me
ish.
meJoined: Jul 2003
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by rx7speed
sorry I thought this was teh big block section on the typeRgen forums
rx7, what ever happened to Stu LMAO? He still around?
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
I'll call them tomorrow and see what happens.
well its not the MAP sensor...
gotta check timing and EGR
Quick question. My mechanic (if you could call him that) when he took out my AIR injection system, just plugged the vacuum line that was going to it. Would this cause any problems?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If its plugged right, no that is not a problem.
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
If you removed all of the AIR and EGR stuff, you'll need to redo your PROM. The computer still thinks its there and offsets the o2 sensor reading by .100V when the computer thinks its turning the AIR pump on. I haven't seen this addressed yet, thought I'd mention.
I haven't seen anything that mentions reprogramming around the EGR. What I've read suggests that the EGR is only for the control of NOx emissions, where the AIR pump puts in more oxygen to help out the Catalytic converter. Could anyone else elaborate a bit more?
). The one in my Navigator went, but the wife made me replace it because she was "concerned", that one was $250
. Thread Starter
Not all of was taken out. Just the pump off the accessory belt and the tubes that went into the old manifold.
The EGR is still functional and hooked up. Could this be a problem?
I've changed the air filter, fuel filter and MAP sensor..still same problem. I have yet to check the timing...maybe faulty injector?
None that I've seen but I'll take a closer look now that you mentioned it.
So after being thoroughly stumped and extemely aggravated at my prior mechanic, I decided to find an ASE certified mechanic to fix my problem. I took it to Motor Masters in Rockaway, NJ and the guy Mike is awesome. He kicked my timing ahead about 3 degrees to help with the added flow. He checked over everything and basically once the car warms up and goes into a closed loop, the 02 sensor causing the car to run lean because my air injection system is no longer there. So I have 2 options, put the air injection system back on, or burn a new chip for the ECM to correct the false readings. If my old mechanic still has my parts I'll probably just put the air pump back on. If he doesnt and I need all new parts, then I'm sure its just cheaper to burn a new chip.
Just wanted to update you guys in case you were wondering.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
how are you gonna hook up your air system when the headers dont have the hook up for the air system. you would have to cut the piece off the stock manifold and weld it into the header on the passenger side to hook it up. I havent had any problems with my headers being on my 3.1l.
a bung needs to welded to thread in the tube going from the air pump.
He said it not a problem..but labor would cost more than burning a new chip.
Did you take out the air pump? I have the headers going to a high flow cat and 3" american series flowmaster. I think a combination of the mods plus the air pump being gone are causing a ECM issue. There is nothing else to explain it. Everything else checks out: EGR, MAP, injectors, timing, transmission, all sensors, plugs, wires. I mean what else could it be but the ECM?
You guys figure it out and ill thank you for life.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
hey man keep me updated on how much it costed to have that piece welded on to get the air pump to work and how much better it runs cause im am a short drive away from whatever shop your taking it to.
Engine: 350 S-TPI
I was looking at the air pump on my new car. The mount on the back of the pump looks like the same mount for the V6 egr to intake pipe. If so, that would be super easy to fab up that style of mount and find gaskets.
Just an .02 for someone to look into.
Car: check
Engine: check
Transmission: check
I mean, my main problem is fixed...but the engine bogs down now. I replaced the air filter..that helped...a little. Then replaced the fuel filter...that helped alot. But still is happening.
- and -
The bog happens not at WOT but maybe half throttle when you take off or are cruising at 30 or 40 and push for a little more speed. Maybe that will help your diagnosis.
- and -
While in closed loop the feedback from the O2 sensor can correct for some of this. But not all. Which is why it started to run better with the O2 sensor connected.
RBob.
Most likely you need some chip tuning. With the headers in place the VE of the engine has been increased. There are tables in the chip that define the engine's VE at multiple MAP & RPM points. These values are no longer correct.
RBob.
RBob.
I need a chip burned and don't have the eqipment nor time/patience to do it. Can anyone burn one for me or point me in the right direction? I'll give you the list of modifications to take into account and I'll pay you of course.
Reply here or PM me or email me AdmAnt13@optonline.net
Let me know ASAP.
Adam
Let me know ASAP.
Adam
