Found a missing bolt and need size on it soon.
Old Jun 5, 2007 | 04:40 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I found the likely cause of the bad vibrations arond the PS pump. I completely forgot that this bolt is there as you cannot see it. It is the bolt that attaches the bracket to the block . The bracket kind of angles down and goes lower on the engine to where you cannot see the bolt at all. I believe that mine vibrated out. I can feel the hole but not the bolt. Can someone give me the size, length, and thread on the bolt so that I can go buy a new one at Lows or Home Depot tommorrow.
Old Jun 5, 2007 | 05:46 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Re: Found a missing bolt and need size on it soon.
I don't know the thread-pitch on that bolt but I do know it's a 13mm or 1/2 in. head by one inch long bolt. I didn't pay attention to whether it was a standard or metric bolt when I had it out last week but I know I used a 13mm socket on it (be prepared to bust out the 1/4 inch drive set, it's tucked against the clamshell for the motor mount pretty well).
A 13mm will also snugly fit a 1/2 in though, so it may be 1/2 in. Most american cars still use SAE size bolts when threaded to the block.
Old Jun 5, 2007 | 06:22 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
you can go to your local dealer and pay a couple of bucks for that exact bolt replacement, that's what i did for a few of my odd-ball bolts
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I figured that it was around that size. I am going to go to the junkyard tommorrow to see if there is one in one of their F-bodies. There are plenty of cars there, but just in case I may need to go to the hardware store.
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
bjpotter
Aug 12, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
antares57
Aug 6, 2015 07:47 AM
