Oil change and "chugging"
Old Jun 7, 2007 | 06:32 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I decided to switch from 5W-30 to 10W-40 because of the hot weather and high mileage. After the oil change, I hear a "chugging" sound like an exhaust leak. So, I put it on ramps and look for what I think is an exhaust leak being unable to find one. The sound seems to come from in back of the oilpan. I did'nt notice this til after the oil viscosity change. Can this happen? Also, it has a stumlbe after revving down from a cold start which I'm thinking also due to the oil change in weight and it does'nt do it the rest of the day once the car is hot. Whaaaa?????
Ken
Old Jun 7, 2007 | 09:02 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Oil change and "chugging"
My elders always told me high viscosity for high mileage engines.. the thicker stuff helps "fill in the gaps" when you have worn engine internals.
Old Jun 8, 2007 | 12:10 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
probably your oil pump protesting having had a thicker oil when its made for 5w30, or 10w30. you only need to run a thicker oil if the car will see like 100* or higher days on a regular basis, and by thicker i mean going 5w30 to 10w30.
Cold regions use 5w30
Moderate regions can use either
and Hot regions use 10w30
I change oil in cars all day and i have seen people come back after bein told by some "mechanic" to run this thicker oil and they have problems. BUT they wanted the thicker stuff so... now that mostly applys to going strait 30w or mabe to 20w50 but still it does make it harder on your Oil pump.
Old Jun 8, 2007 | 08:54 AM
mvftw's Avatar
Run 10w-30 now...
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
