i have no spark
Old Jun 11, 2007 | 08:26 AM
pairtoe's Avatar
i have no spark
ive got a new coil msd blaster, a new msd cap and rotor, new plug wires, brand new sprak plugs, and new distributor but it still not getting any spark. the car ran fine before i changed the starter. and it keeps blowing the crank fuse any ideas why?
Old Jun 11, 2007 | 09:24 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: i have no spark
Was the engine running fine with the MSD already hooked up? If not, re-inspect it's grounds (might also be why your blowing your fusible link). Make sure your battery terminals aren't loose (another possibility regarding your fusible link)....
Old Jun 11, 2007 | 11:05 AM
pairtoe's Avatar
Re: i have no spark
yeah battery reminals are good. i found out wich wire it is thats causing the fuse to blow. but i dont know what to do know. should i trace the wire and see if its torn or something? and what amp is the crank fuse supposed to be?
Old Jun 11, 2007 | 12:12 PM
pairtoe's Avatar
Re: i have no spark
i found the problem. one of the wires that goes to the starter got melted in half by the headers and i keept overlooking it, so i soldered it back together and im good to go.
Old Jun 11, 2007 | 12:27 PM
daves12secV6's Avatar
Re: i have no spark
im curious did u get an msd box or just a coil???
with as much nitrous as u plan to spray i would highly suggest getting an msd 6al and putting in a rev limit chip 200 or so rpms before the ecms fuel cut
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
