Project : Twin Turbo Camaro
Re: Project : Twin Turbo Camaro
yeah u know the big black rubber plug on the back of the throttle body,it kept blowing out the back under boost so we zip tied it to the intake well that held up but the couplers kept blowing apart.
i need a break from the car for a bit as me and rob thrashed on the car every night from like 6pm to midnight for almost 2 weeks to get it ready.for last night.
atleats now i have some data logs to tune a bit more. i am seriously out of injector, i was seeing duty cycles as high as 125%.last night was a bad night to run as well with ambient air temps being in the 95* range, in boost i was seeing 180-200* air temps after the intercooler.
i was also getting very audible knock and pinging right before the pipes would blow off,so i have some timming issues that also need to be adressed before i make another pass.
but as rob said video will be up in a few days
next time out i will have a wideband in the car
oh btw as far as wieght reduction my car now wieghs in at nice 2900 pounds,and ive still got alot of wieght to remove from the car so i should be looking at a 26xx range by the time im done
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
rob ill give u access to my webserver so u can upload it there this way ppl can download the full screen/high quality vids instead of the shitty quality youtube vids
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Could you take a picture of the car? I'm skeptical that you have it that light. How are you measuring it? Unless you have a plexi rear hatch and front there's no way you are lighter than me. We have the same drivetrain and chassis and I know mine is pretty close to completely gutted!
Car: 1989 RS
Thats just crazy. I've gutted the hood, removed the hinges/latches, no front nose baffleing, no ac, no smog, no cat, auto tranny, no rear carpet, no rear seats, 4th gen cloth fronts, no hatch struts, no rear crash bumper, 16x8 crosslaces, no heat shielding, 4th gen rear disk brakes.
And I'm 2930lbs with half tank!
How did you do it differently? I want the car lighter myself, so share your secret!
fiberglass hood, no ex system(just a dump pipe on the turbo outlet) ac delete no heater box. removed all the heat shields under the car,no rear seats or front passenger seat, weld draglight rims,no carpet padding,and the car dosent have power anything except for door locks, the car wieght was 29xx its 3,100 with me in it with a half tank
29xx its 3,100
Let me drive and we will save some more seeing I'm a pipsqueek with a mean right uppercut, lmao.
Car: 1989 RS
I had mine weighted at a dump with a certified scale. I think they must be off though. They said my flatbed trailer weighted 800lbs
They must be off, but its certified?!?!?! Hopefully I can get a car scale put together some day.
Just for the record, which is lighter? A hardtop, or a ttop without the tops?
They must be off, but its certified?!?!?! Hopefully I can get a car scale put together some day.Just for the record, which is lighter? A hardtop, or a ttop without the tops?
Updating this thread for Dave;
Here's a short little clip of us arriving at the track, w/Dave making some last minute adjustments to the MegaSquirt. You'll hear Paul in the background telling Dave to spool it up. Streetfire did an excellent job of messing up the sound (the crackling must have been a freebee lol)....
Enjoy! Click here....
Update continuation;
Here's a little clip of Dave spooling up the turbo, which, I might add, has absolutely no problem doing upon light throttle. Afterward, he then makes his way over to the lanes to make his pass....
Here's the clip of Dave making his way through the burn out box, giving quite the crowd pleasing burn out performance. Unfortunately, due to the intake piping being blown off, along with some excessive pinging, dave had to shut down just past the 330 mark....
Enjoy! Click Here....
Final Continuation;
Back in the pits, we're pretty confident we got the bugs all worked out (considering no wideband to tune with). Intake tubing is back on, and the pinging is somewhat gone. Of course, the track is done for the night, but she would have made a very impressive run, nonetheless....
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Looks like the car is cimming along pretty well.
The noise at the end of the video sounded scary. What was that?
All I heard is the trailer creeking.
Dave, the car sound good (actually a lot like mine does, lol).
Can't wait to see some times from 'ya. (also can't wait for this 3.4 to get here, wooooot).
Edit: Thought you were referring to Paul's run. The noise you heard was Dave slamming into the wall at the end of the track at a whopping 5-mph....
^ My buddy Tony is coming down with his '07 Eclipse, we're probably heading over there tonight. You coming.....?
yeah can ya pick me up
btw should i call up tom?
Last edited by daves12secV6; Jun 30, 2007 at 08:36 PM. Reason: Automerged Doublepost
^ If Mike is going, I'm sure Tom will be around. Prolly not leaving for awhile, still waiting for him to get here. Don't feel like racing the LS1 tonight, so I'm only riding shotgun. Should be a good time though. either way.....
heres a sample from my data log
i only stalled out to 2500 on the line,but within one sample of going wot i was into boost
though the 140% duty cycle didnt help,i also short shifted the car @ 6800 instead of my usual 7200+
top graph
yellow = rpm
purple = map
bottom graph
grenn = tps
red = duty cycle
dam auto resize
http://i76.photobucket.com/albums/j3...s2k3/graph.png
top graph
yellow = rpm
purple = map
bottom graph
grenn = tps
red = duty cycle
dam auto resize
that top one is my second pass
this one is my first pass
top graph
yellow = rpm
purple = map
bottom graph
grenn = tps
red = duty cycle
click link for full size graph
http://i76.photobucket.com/albums/j3...es2k3/run1.png
7400 rpm max this timeso much for ppl saying i kept my foot in it the whole way down the track.
wot threw 1st of on the 1-2 or right after the 1-2 shift then 25% throttle the rest of the track on pretty much both passes
top graph
yellow = rpm
purple = map
bottom graph
grenn = tps
red = duty cycle
Uh, I guess I fell behind on this thread
