bad cat?
Old Aug 2, 2007 | 03:43 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
bad cat?
Hey guys, just the other day I heard this pretty bad rattling coming from my exhaust. I think it was coming from the cat. It was very loud and sounded pretty bad. It just started suddenly too. Does this mean my cat went bad?
If i need to replace it, what would you guys recommend I use? Thanks in advance guys!
Old Aug 2, 2007 | 04:38 PM
atomicskr's Avatar
Re: bad cat?
Check your hangers..... cat usually don't make a racket they just make your car run and smell funny.
Old Aug 2, 2007 | 05:09 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: bad cat?
It could rattle from something braking loose.
y cars cat did that. I tap it with a hammer running and I could hear it. NOn running and it rattled
Old Aug 2, 2007 | 06:43 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: bad cat?
You are most likely experiencing noise from a hanger that goes near the transmission mount. Look for some bolts to have loosened up and moved the hanger bracket.
Old Aug 3, 2007 | 01:12 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: bad cat?
yeah it does that too. I tap it with the bottom of my palm and it rattles a bit. It sounds like its coming from inside the cat itsef, but I'll go and check the hangers again.
92firebirdguy
Sep 1, 2016 07:53 AM
mud runner
Nov 2, 2015 07:30 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Stryker412
Sep 7, 2015 09:11 AM
