idle is bad please help
Old Aug 16, 2007 | 07:41 PM
odla's Avatar
i have a 89 2.8 i did a tune up wires, plugs, cap, rotors, ecu. to try and fix it. it idles at 7-800 but dips to 300. sometimes it stalls the car. if in park it does not stall, but if i put it in drive or reverse it sometimes will stall. I was thinkng injectors? I took it to a dealer to get the wirring from the fuse box to the injectors replaced because they were shorting out and turnning off the passenger sind bank of injectors. so i think that may have craped out the injectors. i havent change them in 190,000 miles. i do have an exhaust leak but thats been there for a while. any help is greatly appreciated. my other car is also starting to crap out so i need to try and get this going. thanks.
Old Aug 16, 2007 | 10:50 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: idle is bad please help
Are you getting any codes? This could be a few sensors.
Old Aug 17, 2007 | 05:58 AM
odla's Avatar
nope no codes
xxx3man`
Sep 23, 2015 10:37 PM
mike_c
Aug 27, 2015 04:32 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
