serpentine belt
Old Aug 24, 2007 | 11:30 PM
thebigpimpdadd's Avatar
Car: 89 Rally Sport
Engine: 2.8
Transmission: manual 5
Axle/Gears: ???
serpentine belt
hey, i needed to remove my serpentine belt to get my hands in there to replace the heater hose off of the water pump. when i was finished up i went to put the belt back on it was almost like the belt had shrunk a good 2 inches. i measured it and it was 86 and 3/4 inches long. i checked a couple parts web sites and that is the longest belt available. did i do something wrong when i removed the belt? i thought i followed the instructions listed in the manual.
Old Aug 25, 2007 | 09:01 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: serpentine belt
You have to loosen the tensioner pulley to get the belt back on. I have slipped the belt on on a couple of occasions on the side of the road but just loosen the tensioner pulley to get it back on.
Old Aug 25, 2007 | 10:07 AM
firstfirebird's Avatar
Re: serpentine belt
Put a 15mm wrench on the bolt in the center of the tensioner pulley. Turn it counter-clockwise and it's spring loaded, slip the belt on and release.
Old Aug 25, 2007 | 12:40 PM
Car: 89 Rally Sport
Engine: 2.8
Axle/Gears: ???
Re: serpentine belt
yeah i did the whole 15mm wrench thing and it still seems the belt is too small even with pulley completely turned counter clock wise.
Old Aug 25, 2007 | 01:29 PM
Re: serpentine belt
Are you sure you didn't wrap it the wrong way around the crank pulley/water pump? It can go either direction around them. If you are still having trouble, I will dig up some pics...
Old Aug 26, 2007 | 06:20 AM
UK Speedbird's Avatar
Car: 91 Firebird
Engine: 3.1L 191ci
Re: serpentine belt
Funny that, I replaced my belt a while back and it came off easy. Then I needed to move the alternator to get to the number 1 sparkplug and couldn’t shift the belt even with the tensioner at maximum slackness. Fast forward a few weeks and it came off with no probs! Go figure!!
Old Aug 26, 2007 | 11:06 AM
Car: 89 Rally Sport
Engine: 2.8
Axle/Gears: ???
Re: serpentine belt
my camera broke a few weeks back so i couldn't take a pic of the belt route. my water pump was the only accessory that spun in a counter clockwise rotation. i might be mistaken though.
Old Aug 26, 2007 | 11:40 AM
Car: 89 Rally Sport
Engine: 2.8
Axle/Gears: ???
Re: serpentine belt
thank you firstfirebird i went out and swapped it around and it worked perfectly. problem solved. now just need a new camera to avoid these problems in the future.
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
