Overheatd, now engine knocks
Old Sep 20, 2007 | 03:43 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Hey guys, ill try to make this as short as possible. The other day my car overheated bad. Engine started smoking, then came the knocking. I looked in my radiator and saw that there was pretty much no water. So I could have prevented this, I kick myself in the a** everyday for it. But is it possible that I just threw a main bearing? The car ran fine before this event. Any help would be great. Thanks.
Spence
Old Sep 20, 2007 | 08:28 PM
firstfirebird's Avatar
Re: Overheatd, now engine knocks
Did you change your oil since? You may have collapsed a lifter, or spun a rod bearing, but I doubt a main. There is also a chance that you blew a head gasket, and leaked water in the cyl causing the rod bearing failure.
I would suggest doing a compression check (testers are cheap), if that's ok, add a quart of tranny fluid with your oil change in place of 1qt of oil. Wait a few hundred miles, and change it back to all oil. This would help a stuck lifter.
A rod knock, well, you can check through the oil pan while the motor is still in. I did a writeup on how to remove oil pan with the motor in the car here in the v6 section a while back. You would pull the pan, then a couple or rod/main caps to check the shape of the bearings.
Do you have any audio/video for us, the type of sound makes a big difference on the determination of what it is.
Old Sep 21, 2007 | 10:05 PM
I forgot to mention that it's a stock 3.1. But I have no videos or sound clips of it. I will say that I can feel the vibration when I give it gas from the throttle lever on the carb. If that helps any. Also after it reaches operating temp, when I put it in drive the oil pressure drops below 0. I will try to get a video soon. I really want to get it back on the road, I miss those compliments and stares. Lol.
Old Sep 21, 2007 | 10:31 PM
Too bad you aren't a little closer, or I would be glad to help. I'm about 2hrs South of you.
See what you can do for a soundclip/video. It would help a lot since the description af a sound can be vague.
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
