Is there any other way to know what type of Rear you have??
Old Sep 28, 2007 | 05:26 AM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
I tried looking for the stamp on the rear and I can't find it at all. The Haynes manual side the front right axle but I couldn't see it.
Is there a way to know what rear you have with the VIN number?
The car is a stock 90 Camaro RS.
Old Sep 28, 2007 | 12:47 PM
badinfluenceRS's Avatar
Car: 1994 Trans Am - 1992 Firebird
Engine: LT1 5.7 V8 - 3.1 V6
Axle/Gears: 3.42 / LSD
Re: Is there any other way to know what type of Rear you have??
place car in neutral on jackstands/lift etc
Put a pice of tape on the tire, recording/remembering exactly where the tape orginally was.
Spin driveshaft with hands. Count the number of times the driveshaft rotates until the tire has made 1 complete revolution based on the tape you placed.
The driveshaft will spin x.xx amount of times...
for example, if it spins 3 and 1/4 times, you have 3.23's. A little less than 3 and 1/2 times, probably 3.42's...etc etc
get it?
Old Sep 28, 2007 | 02:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If it is the stock rear, with a T5 it is a 3.42, with a 700R4 it is a 3.23 (was typo'd at 3.32, which is incorrect). Most likely an open (non-posi). Can also check the RPO codes on the glove box lid under the hatch. There is a list of them here on TGO.
If your '90 is truely stock then it has a 3.1l engine, not the 2.8l.
RBob.
Old Sep 29, 2007 | 01:23 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
yea its a 700r4.
I'm asking this because I want to change the fluid and I need to know how much (if any) fluid has to be added for the limited slip (think thats what its called). There is nothing in the Haynes Manual that I saw telling you how much to add.
Old Sep 29, 2007 | 01:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Ahh, for fluid the rear takes about 1.8 qt's. Basically you buy 2 qt's and the additive. Add the additive first then fill with gear lube until it trickles (pours!) out the fill hole.
RBob.
Old Sep 30, 2007 | 08:56 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
RBob.
Did you or someone else swap in a 2.8?
Old Sep 30, 2007 | 10:19 AM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Yea I swapped the engine n tranny from my 89 rs to the 90.
by stock i meant its a stock rear. Sorry bout the confusion.
RBob.
Since I've never done this before can you tell me what the good fluids to use would be
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
