i really need help!
Old Oct 17, 2007 | 09:47 PM
adam86's Avatar
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
i really need help!
1986 Firebird 2.8 AUTO 2.77gears
alright this is my major issue.. the gas mileage is very much a part of the problem. but my idle and acceleration is very bad
when i start the engine in the morning or after it cools it runs horrible. idle is very lopey(unstable) if i put it in gear the engine almost stalls at about 500rpm but raises to 650-750 after acouple seconds.
When i rev the engine to 3k rpms it sound real good but at 2k or lower its not soo good.
if i put it into gear and try to take off it hesitates for a second then accelerates but its pretty rough.. it does the same thing in park.
once warmed up the hesitation is almost gone but the engine is still not smooth and the idle is lopey... mileage is about 13mpg.
vacuum is 13 in park, 10 in drive with no leaks anywhere
if anyone knows of a sensor that i've not replaced that may be the problem or something i've over looked please let me know
i've replaced
Timing Chain
Manifold gaskets
Spark Plugs
Plug Wires
Ignition Rotor
Distributor Cap
PCV Valve
Water Pump
Alternator
Battery
MAF sensor
Fuel Filter
Rebuilt Transmission
Wheel Bearings
Vacuum lines
USED Rear end(good)
USED FWD Injectors
USED 92 Camaro Coil
USED TPS
USED Ignition Module
USED Fuel Pressure Regulator
i've spent more on parts than i paid for the car so this is really starting to bother me
Old Oct 17, 2007 | 10:07 PM
EricW's Avatar
Car: 1989 Firebird
Engine: 2.8 MPFI v6
Transmission: TH700r4
Re: i really need help!
When did the problem start, after you replaced everything or before? was everything changed at once or one at a time?
Old Oct 17, 2007 | 10:10 PM
adam86's Avatar
Car: 1989 GTA
the problem was from before... i've replaced all the things over the last year.. when ever i had spare cash i would replace something
but nothing has fixed the problem.
Old Oct 17, 2007 | 10:33 PM
EricW's Avatar
Car: 1989 Firebird
Engine: 2.8 MPFI v6
Does it run any better if you play with the distributer? you can try spraying intake cleaner around the seals and intake when she is running and see if the rpm spikes. this would show a vacuum leak. There is a possibility that the harmonic balancer slipped and moved the timing mark. if its been dropped or the rubber decays the weight has a possibility of slipping around the spoke. this is rare though... but it might explain the running better at high rpms but not the running better when hot. make sure all plugs are connected.
