Multimeter and TPS
Old Oct 19, 2007 | 12:35 PM
adam86's Avatar
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
Multimeter and TPS
have the digital multimeter and jumper wires..
i disconnect the harness connecter and put the jumper wires in both the TPS and connecter on harness... then i put the multimeter connecters in the harness with the wires
dark blue wire goes to the positve and black goes negitive..??? is this the correct way????
what setting on the multi meter do i use?
it has V with a solid line and dots and has these settings:
200m/2000m/20/200/1000
the V with the ~ has:
750/200
the other one is an A with a solid line and dots:
200u/2000u/20m/200m
and OHMS do i use this?
does the black plug in on the multimeter that says COM is that negitive? and do i plug the positive into the red that has a V and an ohm sign next to it?
i was messing around with all the settings and i could get it to say .5 but when i goto WOT it only goes to 1.8 with 2 different TPS'
Old Oct 19, 2007 | 01:13 PM
Shroomie's Avatar
Car: 89 Camaro RS
Engine: 2.8L
Re: Multimeter and TPS
Basically what you're going to want to do it put the black lead on ground, and the positive lead on the middle wire on the TPS connector.
Set the meter to Volts DC (solid line with dots). I'm not sure on what range, it's been a while since I've used one like that. I think you're supposed to use the first one higher than what you're measuring so I guess that would be 20V.
When you finally start getting a reading, turn the sensor until you get .54V (or 540mV).
That sounds like the right spots for the leads. Like I said though, it's been a while since I've used one like that.
Old Oct 19, 2007 | 01:18 PM
adam86's Avatar
Car: 1989 GTA
i've been using the v with the dots and lines with the 20v setting but i keep getting weird reading that im not looking for....
i tried it for about 4 hours yesterday and got pissed off and just tightend it down where it was..
hopefully i will have more luck today.
Old Oct 19, 2007 | 01:34 PM
adam86's Avatar
Car: 1989 GTA
i just went outside to try it again and still nothing...
the only reading i can get is .5 and i can get a ohm reading too but its like 2.58something
is it the meter im using? anyone had this problem?
Old Oct 19, 2007 | 02:31 PM
adam86's Avatar
Car: 1989 GTA
i figured it out... i didnt have a 3rd jumper wire connected to the 5v connection..
as soon as i hooked it up i got a voltage reading..
0.56 at idle
4.97 as WOT
that right?
Elephantismo
Feb 13, 2019 12:51 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
lanceflame44
Sep 25, 2015 12:28 PM
