Help engine wont carnk over!
Old Oct 21, 2007 | 04:00 AM
camarors88's Avatar
alright so ive searched the threads for quite awhile and didnt really find anything, my problem is, i was driving one day, wasn't beating on the car or anything and it just died, and i had to tow it home, any ways got it home and checked everything i could think of, the altenator, the starter, battery, connectrions, just wotn turn over, also tried putting it into 2nd, 3rd, and 4th gear while being pulled at various speeds, and nothing, i have a full tank of gas, new fuel pump and i hear it turn on when i turn the igniton on, any help please? also my car is an 88 camaro rs, 2.8 wtih the 5 speed transmission.
Old Oct 21, 2007 | 10:13 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Help engine wont carnk over!
It's not a fuel problem if it's not cranking over at all. Most likely a bad ground.
Old Oct 21, 2007 | 05:23 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
wont turn over? you mean... wont start up? or wont turn when you try to start it (meaning no ... whir whir whir, VROOOOOOM!) which what im trying to say is when you turn the ignition to start, does it just click? do nothing? have you checked the neutral safety switch?
Old Oct 22, 2007 | 08:38 AM
camarors88's Avatar
lol it just clicks, nuetral safety switch? and if its a bad ground? where would i go about checking those? i assumed i had a good ground as the starter trys to turn over the car and fuel pump turns on and all the gauges and lights turn on, i have no idea what else to check...
Old Oct 22, 2007 | 02:13 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Have you tried to manually rotate the crank? Do you get any codes (SES light)?
Old Oct 22, 2007 | 08:30 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
If all you get is a click, then you either have a bad connection at the starter, bad starter motor/solenoid, or bad engine ground.
With a car that doesn't start, how did you check the alt? did you remove it and have it checked somewhere?
Check the negative battery connection where it bolts to the front of the engine down near the air injection pump.
Old Oct 23, 2007 | 02:30 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
could be a bad solenoid too
anyways, try this... get a flashlight and look at your starter. there are 2 big posts on it with red wires on one and black wires on the other. get a medium sized screwdriver (that you wont use much and dont care what it looks like). put it on the 2 big posts where u see all the wires (cross them both and make the screwdriver a link to the two) if it kicks, then you have something else wrong. if it doesn't kick (or spark) then it's the starter or battery (no power from batt)
if it sparks then u have good ground, usually.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
