'89 2.8L IAC routing.
Old Dec 2, 2007 | 05:30 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I'm working with an '89 2.8L MPFI and need to know where the IAC sends it's air. The passageway infront of the throttle body goes to the IAC, then out the big nipple to the side of it.
It appears that it would attach to the lower rear of the manifold (just infront of the distributor) and Tee-ed with the PCV.
Is this correct? It doesn't appear to let the air in behind the throttle blades like a TPI setup.
-Paul
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
bplessy
Sep 30, 2015 12:14 PM
