Need comparison engine
Old Dec 8, 2007 | 07:10 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
This only applies to 86-89 2.8's ('302 ecm). Need your average LV8, g/sec and BPW at idle, low speed cruising (30mph) and highway cruising (55mph) (or better yet a datalog) so I can compare it to what my '165 is telling me. Looking for a healthy, mostly stock engine but since that may be hard to find give me the details on your engine.
Now onto how it's going on my end. Idle is solid, better than when it had an '870. Low end response is good and low speed cruising is decent, but an occasional misfire. BLM's stay fairly close to 128, but the INT flies all over the place between 128 and pegging at 75, averages 100. Hot restarts are occasionally problematic, down on power and dataloggs show it's cutting timing, not sure why. Slight hesitation at ~60% throttle, but not substantial. Overall it's running well, but down on power. I've transfered as much of the stock calibration as I can find with a few minor changes to improve driveability. I don't have access to a $3A hack (not sure if one exists) so I had to fudge a few things, but I'd say it's 80-90% stock tune.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
