Tired of 4 cyls. kickin' my a**.
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Tired of 4 cyls. kickin' my a**.
There are atleast 3 different 3.8 engines.
Carbed Chevy 3.8 which is a 305 with 2 cylinders hacked out.
Early Buick 3.8 = Debored 350 Buick V8 with 2 cylinders chopped out
Late Buick 3800 = Early model V6, refined with SFI, DIS, and the 60*V6 bellhousing to mate up to the FWD transmissions. This same engine was used with the 60*V6 version of the 4L60E used behind the 2.2/3.4/and 3.8.
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Fast355 is correct. The 3800 series II uses the same bellhousing bolt pattern.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
All of the front wheel drive Buick V6 engines (GM 3.0, 3.3, 3300, 3.8, 3800) and the 4th gen 3800 rear drive engines use the GM Metric bolt pattern. It's pretty easy if it's automatic, it's the standard shift engines I am having a problem with. Finding a flywheel is hard work!
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
ohhh i had a 91 caddy with a 4.9, all it had done to it was an accel coil, and it would wax azz and fry tires, it had a multi port port injection, with a throtle body on it, looked like the TBI to multi port conversion that edelbrock sells,but it was stock. i think putting one in a camaro would be cool, a 3800 would be sweet also, didnt thay have a supercharged 3800??? that would be even sweeter.
Engine: 2.8/TBI/TPI
Get going on it, then! I'm too garage challenged to get my project rolling for now; I'm dying to see more hybrid projects!!
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Yeah the v6 does suck but u can just drop in a 350 with all that room under the hood .... mmm but with my V6 firebird i beat many *****s with soup can mufflers.... but now with the 350 im beating them faster
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Y'know, this is the v6 board. Comments like that should stay in the v8 or engine swap boards.
Car: '86 SC
Engine: 2.8
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Tired of getting beat by 4 cylinders I've got a solution that won't cost a dime find a 2.3 mustang lx and race it. Just remember it could always be worse you could be driving a mustang.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
