question about timing gear spaceR?
Old Jan 4, 2008 | 05:26 PM
jaseman2134's Avatar
Car: 1987 camaro
Engine: 3.1
theres a metal... what looks like a type of spacer that runs the length between the cam and crank gears and keeps the chain from going in too far. the top of the right(driver) side is broken off and is nowhere to be seen, the question is if it will be ok if i leave it there or if i could file it down to smooth that edge or should i just try to find another part?
Old Jan 4, 2008 | 05:28 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: question about timing gear spaceR?
Like this? Ive heard that, for some reason, these engines are prone to do that. Although I dont know it is a bad thing to leave as is.
Old Jan 4, 2008 | 05:38 PM
Car: 1987 camaro
Engine: 3.1
yep, looks like i took the picture myself lol. its an ingenious design. thanks
Old Jan 4, 2008 | 09:10 PM
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
If you have it down to that point already, you might as well just replace the dampner. I picked up one for mine (when I replaced the timing chain) for less than $10 at Checker.
Old Jan 4, 2008 | 09:50 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
mine is broken at the exact same place! and my timing chain skipped too, so maybe that damper had something to do with it. i'd replace it. i am actually. napa has them on their website.
Old Jan 5, 2008 | 02:44 PM
Car: 1987 camaro
Engine: 3.1
NVM i found it, im just being stupid
thanks guys
customblackbird
Aug 15, 2021 10:16 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
