TB question
Old Feb 5, 2008 | 08:11 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
TB question
I was just wondering if there is a way to take the shaft, that holds the tb plate on, out of the tb? I had heard once that it is just a pressure fit and with a few hits with a hammer it will pop out...nope It is locked shaft is locked on the one end by a circle plate, and I cnt figure out how to get it out...without destroying it.
Has anyone taken this out?
Old Feb 5, 2008 | 08:20 PM
firstfirebird's Avatar
Re: TB question
Let me go look at the stock 3.1TB, but if it's the one I remember, you have to file off the "mushroomed" shaft near the pull. It's kind of an oval shaft pressed through a plate (the the cable attaches to), then flattened on the end to stay in place.
If that doesn't make sense, I'll get out a TB and show you if you need.
Old Feb 5, 2008 | 08:25 PM
grimmcs's Avatar
Car: 91 Camaro
Re: TB question
Thats what I was thinking, but than that peice wouldnt be able to be used again. Mabye I could drill into the end, where the flatened part was, and put a screw into it.
Old Feb 5, 2008 | 08:35 PM
Re: TB question
Yep.
You could probably use a Dremel to get most of it off, then file it nice and flat. If you know someone with a welder, one spot would do the trick as well.
Old Feb 5, 2008 | 08:39 PM
grimmcs's Avatar
Car: 91 Camaro
Re: TB question
Thanks. I was going to file down that part but I didnt want to mess it up by doing it wrong. Now to see if I know someone with a spot welder.
The gerbel is running again...
Old Feb 6, 2008 | 01:29 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: TB question
if theres room you could file or dremel a small grove round the shaft and use a C clip or somin?????????
just another thought
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
