What part is this?
Old Mar 12, 2008 | 04:15 PM
Buss54's Avatar
What part is this?
I know this is tied in with the cooling system, either this part is leaking or the hoses to it and im curious to what exactly its called. Damn car keeps overheating.
Old Mar 12, 2008 | 04:47 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: What part is this?
Thats the heater control valve.
Old Mar 12, 2008 | 04:48 PM
Buss54's Avatar
Thanks.
Old Mar 12, 2008 | 06:19 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Where the other plastic outlets connect to the main shaft is prone to cracking... if you think you're losing coolant, that's a good place to check. Whole part is $15, if I remember right.
Old Mar 16, 2008 | 08:15 AM
firstfirebird's Avatar
The heater core bypass can be eliminated (pictured part). It causes coolant to NOT flow through the heater core while the heat is off via a vacuum "switch". Since your HVAC closes the door in front of the core during A/C operation or heater "off", you don't need the bypass if the door is functioning properly.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
