code 22 and 34 why? I just changed the thermostat
Old Mar 29, 2008 | 04:03 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
What in the hell is going on!! All I did was change the thermo and now it idles at 2000rpms and when I try to give it gas it cuts out and stalls. I had to take the upper intake off to remove the thermo. This is what I did.
Remove UI, unhook vacume lines at back and at TB, unhooked sensors on TB, remove the tube from the the map and TB. I didn't force anything or break anything.
I've read what the codes are but that doesn't mean anything to me. I've got a tester but hell if I know how to use it. I guess I can learn.
I noticed that where the vacume lines plug into the TB there was a piece of rubber stuck in one of the holes so I removed it and installed everything and this is what's going on. It ran fine before I did anything. Something doesn't make since.
What simple thing can I try to resolve this?
also, I've pulled the intake apart a dozen times or so and never did it do this.
Old Mar 29, 2008 | 04:16 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: code 22 and 34 why? I just changed the thermostat
Well code 22 is for your TPS and code 34 is your MAF. I would check those things.
Old Mar 29, 2008 | 04:21 PM
micali's Avatar
Engine: 2.8
I checked the tps plug and one of the pins where pushed back and not touching the sensor. I pulled it up and it's working fine.
Old Mar 29, 2008 | 09:19 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Make sure you've got everything connected firmly, the original connectors get brittle with age. You're sure you have everything hooked up the way it was?
Old Mar 29, 2008 | 10:27 PM
micali's Avatar
Engine: 2.8
its working now, connector was bad
Spyder_TheGamer
Dec 25, 2015 05:07 PM
1992Vortec
Aug 31, 2015 08:05 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
perZ
Aug 15, 2015 01:17 PM
