Starting problem
Old Apr 15, 2008 | 11:19 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Starting problem
I have a 1984 Pontiac Firebird, 2.8. When i drive for a few hours then park it, it wont start again. I turn the key, gauges work, it just wont crank like the starters dead. If i let it cool for 10min it starts fine. What could be causeing this. I thought coil or the starter. Seems like this problem is getting worse. Please help. Thanks
Old Apr 16, 2008 | 08:51 AM
Car: 84' Trans Am
Re: Starting problem
Old Apr 16, 2008 | 11:07 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
sounds like a hot wire. if you NEED to start it, you can cross the + and - sides of the starter with a screwdriver... i've done it many times, but now i just have a push button starter because i dont know what is wrong between the wiring of my ignition and starter... everything works, until i turn the key to engage the starter... and nothin! lol... oh well.
Old Apr 16, 2008 | 05:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd change out the starter. You could just change out the solenoid (sits on top of the starter), but you'd have to take the starter out of the car, and at that point- may as well replace the starter! Don't forget to unhook the negative battery cable first; that big positive wire at the starter can throw a bunch of sparks!
Scottie, if you don't have VATS (a black chip on the edge of the ignition key), and you're not seeing +12 at the solenoid when you turn the key to start, your neutral safety switch (on the shifter) could be bad.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
