Vacuum Gauge location?
Old Apr 17, 2008 | 02:15 PM
Polly_the1's Avatar
I have a '92 3.1l firebird with a surging idle and really bad mileage, and Im going to do a vacuum test this weekend.
Where on the vacuum system do I attach the vacuum gauge?
And will it tell me the overall condition of the vacuum system, including all the vacuum hoses and the brake booster? or just the manifold vacuum?
All answers is appreciated. Thanks.
Old Apr 17, 2008 | 03:23 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Vacuum Gauge location?
Hook it up to the the t-line at the back of the intake manifold.
Old Apr 18, 2008 | 12:19 PM
Polly_the1's Avatar
Where at the T-line? The one that goes to the brake booster or the other one? Does it even matter? And will it tell me the overall condition of all the vacuum hoses o do I just get the manifold vacuum?
Old Apr 18, 2008 | 08:56 PM
91chevywt's Avatar
It will tell you manifold vacuum + the seal of all other vacuum lines attached minus the one you unplugged, which I imagine is what you want. Try it from the other port if you want. If you see any lines you suspect, a good way to test is to unplug the whole line and plug one end while sucking the other end. If it collapses, or you can suck air while its plugged, that line is bad. Even if a line just looks dry or cracked or suspect you should probably chane anyway. Try some carb cleaner around intake gasket surfaces and areas where there could be a vacuum leak. If you see a jump in idle, the motor smooths out, or you see vacuum increase, you probably just found a leak. Just be careful with the spray, dont spray it on your exhaust or empty the can on your motor.
Ghettobird52
Jul 5, 2024 11:18 PM
Jote4805
Aug 25, 2015 06:11 PM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
