OIL prefrences ???????
Old May 7, 2008 | 01:02 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
so then, what do you use ?
i only ask as i changed the oil in my 03 MG and it uses - like many newer motors - quite a thin oil, wereas older cars traditionally use thicker oil. obviously with synthetic and stuff the new oils stay more consistant compared to old mineral oil thats thick cold and thin warm.
just curious
happy motoring ;-)
Old May 7, 2008 | 02:02 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: OIL prefrences ???????
Used to run Torco 0w-30 before it went up to $8.50 a quart. Now I'm "cheap" and use the German Castrol 0w-30.
Synthetic only in all my vehicles.
Old May 7, 2008 | 03:25 PM
CamaroKingpin's Avatar
Car: '92 camaro rs
Engine: 3.1 v6
Transmission: stock tranny
Axle/Gears: stock gears
+1 for the castrol(high milage)
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
you def like the modern stuff then, ive been impressed by it recently so im thinking of using similar in my thirdgen, cant hurt to try anyways.
ive found castrol to be great in the past- all i ever used to use
Old May 10, 2008 | 06:58 PM
oil pan 4's Avatar
Car: 89 Firebird
I use Synthetic shell Rotella T 5w-40 weight oil in every thing.
After much reading on bobistheoilguy.com it is the best for the money. And is better then regular mobil 1.
If price is no object, go with Mobil 1 10w-40 weight "MX4T" now known as "Racing 4T", I believe. It is just about the best oil you can get but its about $8/qt. It was $8.12/qt last time I bought it a year ago.
The Rotella is $17 per gallon.
Mobil 1 is $22+ a gal.
Old May 10, 2008 | 08:25 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
I've been using Pennzoil 10W30 in my engines. No particular reason except that my family(mostly seasoned backyard mechanics) trusts them in their engines.
Old May 10, 2008 | 10:51 PM
oil pan 4's Avatar
Car: 89 Firebird
The only addtive package that is weaker then pennzoil is regular mobil 1.
You guys have flat tappets, SM rated motor oil doesn't have very much in the way of anti ware addtives.
Your cam could start grinding away a cam lobe with out enough of those addtives.
Old May 10, 2008 | 11:47 PM
SageMoonblade's Avatar
It used to be that I ran whatever I could get in the mineral oils until I began running turbochargers, began using Valvoline synthetic to help with the heat from the turbos. Since my sister came home with her husbands Ford Lightening that has never had anything but Pennzoil in it, runs like new and has never had a rebuild, over 400k on the odometer, I have been thinking about switching. That truck has had the living hell beat out of it and still runs like new, thats impressive enough for me. Personally I feel that if you change your oil regularly and don't have high heat or high performance situations (IE: turbos, boost in general, nitrous, 11-1 compression) than stick to mineral oil, its what the aviation community does. If you do run boost or anything that is high performance or very high RPM, consider a synthetic of some sort. Virtually all oils are the same, except for the race oils like AMSOIL or Rotella-T they are somewhat beyond SAE standards. Most important people for the health of your engine, CHANGE YOUR OIL ON TIME!!!!
Old May 11, 2008 | 12:26 PM
oil pan 4's Avatar
Car: 89 Firebird
Yep, the only oils that stand out are going to be your racing oils and heavy duty diesel engine oils.
The best oil filter you can get off the shelf (at Advanced Auto parts) and for the money is going to be the Puralator PureOne serries of filters. There are better filters out there but they cost several dollars, to 2x or 3x the price of the PureOne and they don't really do much more than the pureone. You can pay more and get less, examples of that are the K&N and the mobil oil filters, they cost twice as much and are not as good.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
meeklay812
Oct 1, 2015 03:46 PM
