Fuel gauge is screwed...HELP!!!
Old May 7, 2008 | 03:26 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
OK...here's the situation. I was coming home and the State was doing some roadwork. I hit this hellacious speedbump and I fet hte car was going to break in half. I noticed a minute later that the fuel gauge was all the way to the right and not working. The thing is that all the other gauges are working on that side of the cluster and the right side of the cluster is fine too. Just the fuel gauge is out! I looked on back at the fuel pump connector ( right behind the rear seat under the car) and it seemed good. It still had the factory tab that holds the connector in place. I can;t see it being the cluster if everything is working. I don't think I have a fuse for that as a single gauge either. WHAT can I do!
Ken
Old May 8, 2008 | 11:53 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Fuel gauge is screwed...HELP!!!
isnt there a capacitor or somin that goes wrong?? not sure - my oil pressure dosnt work, same prob all to the right. try the electroncs section/forum instead of v6.......
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
