posi v6
Old May 7, 2008 | 10:25 PM
nightowls_gm's Avatar
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
posi v6
i went to the junk yard and got a posi carrier from and 87 iroc with 2.73 gears.my ? will that carrier fit in my v6 rear end and still keep the origanal 3.42 ring and pinion gears?
Old May 7, 2008 | 10:54 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: posi v6
Your 3.42's should bolt right onto it as I believe it is still al 3-series carrier. You will have to reset your backlash and preload on the bearings though.
Old May 7, 2008 | 11:10 PM
Car: 88 IROC Z
Engine: 5.7
Re: posi v6
that shoulnt be a problem but thanks for your help.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
