Pulling a 3.4 from a 4th Gen
Old May 12, 2008 | 12:35 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
I found a 3.4 at the yard. I am looking at swapping it for my 3.1 since it just hit 200,000 miles...
Anyone pulled this motor from a 4th gen before? Any tricks to it, problems in getting it out, does it come out the top or do I have to drop it out the bottom, can I pull the front off and take it out that way, etc.
Any help from you pros that have done this before would be much appreciated...
Old May 12, 2008 | 01:16 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Pulling a 3.4 from a 4th Gen
The 3.4 swap is quite possibly the most talked about topic on here...
I pulled one from a 4th gen with a perfect front end. It sucked. A lot. My knuckles were red for a week. I had help, and eventually needed another person as well. This motor absolutely sucks to pull out from the top. Supposedly, they're made to come out the bottom, but no way to do that in the scrap yard. My suggestion is to get it down to the LIM, with all accessories off. Pull it out from there and pray to God. You'll need it.
Old May 12, 2008 | 03:20 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Ive never pulled a 3.4 before...but I would assume that if you take off the intake, accessories, and pull out the radiator it would be much easier.
Old May 12, 2008 | 05:01 PM
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
Easiest way to pull the engine is to drop the whole K-member, but that may not be possible at the salvage yard. If you have to resort to taking it from the top, you'll have to pull the radiator and maybe some of the accessories.
Old May 12, 2008 | 11:55 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I had the pleasure of removing one from the top last week. Lose the top end (heads and all), unbolt the trans and yank it.
Give 'er hell, gently.
Old May 13, 2008 | 08:12 AM
forkvoid's Avatar
I pulled mine with the trans attached and unbolted it on the ground. Kept the LIM and heads on. Most difficult part of the whole process was getting the bolts off the UIM from underneath the dash. I still want to find the GM design team for that and punch every last one of them right in the kisser.
Old May 18, 2008 | 07:06 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
a couple peeps from fv6/cv6 have pulled the engien from up top, but yeah, they were designed to be yanked from underneath, the bastards
Old May 19, 2008 | 11:37 AM
Travis&camaro's Avatar
Car: 1984 Camaro
Engine: BIG BAD 360!!!!
Transmission: th350 shift kit 3600 stall
Axle/Gears: 3:73 posi
just unhook all the wire harnass and un bolt the kmember and tranny and shock tower mountes and it all drops right out. I did the one in my 4 gen in about 45mins and I just jacked it up and put the jack stands under the front stub behind the wheel well.. it goies good. you dont have to pull the engine apart and pull it from the top Thats ALOT OF WORK and hard on the hands.
Old May 19, 2008 | 11:53 AM
forkvoid's Avatar
And you're going to do this in a junk yard? Good luck.
My junk yard doesn't allow items such as jacks and jack stands. All vehicles are up on the two-rim method(one rim horizontal, vertical on top of that, welded together).
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
