Power Steering Hose wrong...
Old May 17, 2008 | 04:22 PM
PopCycl's Avatar
Hello everyone,
I recently purchased a 91 Camaro RS V6 and quickly found the Power Steering Pressure hose has a small hole in it. I went to the local parts store and bought the Powercraft 71422 (listed hose for vehicle) only to find it does not match the hose on my car and it is too short to work. I have been to every parts house and they all have the same hose. I have searched the internet and only found the same thing Please look at the pic and tell me what hose I need. The bottom hose is the one from my car. The top hose is the Powercraft (hose listed for the car). As you can see the pump end is not bent at the correct angles causing the hose to be too short.
Old May 17, 2008 | 04:38 PM
project89's Avatar
Re: Power Steering Hose wrong...
can u just redo the bends ot make it fit
Old May 17, 2008 | 05:11 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
But make sure if you try this, you use a pipe bender and not do it by hand.
Old May 25, 2008 | 04:08 PM
PopCycl's Avatar
I took your advice, somewhat. I took the part to a local fabrication shop that bends tubing similar to this an d they bent it for me for free. It bolted right on and no more leak.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
