water pump pulleys
Old Jun 5, 2008 | 01:51 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
water pump pulleys
i have a 3.1 originally out of a 92 camaro in my 89. it was rebuilt and put into an S10. here's my problem though: my 89 2.8 water pump pulley doesn't fit. the spacing of the bolts is too big for the 3.1. i can't find a v6 camaro at the JY let alone a 90-92 3.1 camaro. and the pulleys for the motor are for camaros and not S10s or blazers. so what should i do?
Old Jun 5, 2008 | 05:39 PM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
Re: water pump pulleys
Just get a whole new water pump. They aren't that expensive, and they are a piece of cake to change. Here's one: 1992 Camaro 3.1L V-6 Water Pump
Old Jun 5, 2008 | 07:23 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Which water pump do you have on it?
If its in an s10, you need an s10 pump and pully so you can bolt the fan to it....... unless you went electric.
But if you just need a pully, go in the parts section. I was in there today and someone was parting out a 91/92 v6 3.1 bird.
Old Jun 5, 2008 | 08:28 PM
i know they aren't that hard to change, but i'm trying not to spend money i don't have.
dale, i like the idea. but what do you mean by parts section? i have a few other parts i'd like to get.
Old Jun 6, 2008 | 07:06 AM
Dale's Avatar
Engine: 350 S-TPI
On this board down below, there is a "parts wanted" and "parts forsale" section. Thats where I'm talking about.
Old Jun 6, 2008 | 03:48 PM
well, heres what i've figured out. i did some more research and it is an S10 water pump (****!!!), but i still have my old one along with my timing cover. so i guess i'll put it on, it looks ok, i just hope the water pump isn't the reason the old engine mixed water in the oil pan. (never seen it run, but i assume it overheated probably more than once. call it a hunch.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
