car sputters on highway HELP
Old Jul 2, 2008 | 02:15 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
so as im driving my car jerks ridiculously on the highway.
im talking full fledge.
it sputters in every gear when i reach apprx 3k on the rpm. (sometimes earlier)
The RPM's go haywire (7k to 2k back to 6) i cant drive this thing anymore
i dont know whats wrong with it.
ive checked all the sensors, change all of them just to be certain.
ill be driving and it will be fine for a few minutes then ill hit 3k and boom it stars jerking i hear the engine rattling (like when u **** into 5th from 1st) and a bit of grinding.
is my transmission going bad?
HELP please.
thanks guys.
its 88 rs V6 MPFI T5
Old Jul 2, 2008 | 02:23 PM
project89's Avatar
Re: car sputters on highway HELP
plug wires/plugs maybe ign module and pickup coil.id try the plug wires first though.
if u have a plug wire arching out it will make the car run like total crap+ the tach will bounce all over the place
Old Jul 5, 2008 | 11:01 PM
jrsrnr3's Avatar
You may have a vacuum leak and also check the fuel pressure, maybe the fuel filter might be pluged, fuel pump dying or the fuel pump relay might be bad.
Old Jul 6, 2008 | 09:31 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
i had a friend that had a dizzy that was going to poop, replaced that and it ran great
Old Jul 6, 2008 | 12:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
what codes you getting, and how old is your clutch setup?
Reddeath210
Oct 6, 2015 08:20 AM
zeitghaist
Aug 18, 2015 07:33 AM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
