the bird still isnt running(got a video)
Old Aug 1, 2008 | 07:50 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
iv changed the plugs,wires,cap,rotor,fuel filter,battery,and ignition switch in the past month
but i will turn the key and the car will almost start for about 2sec. and die
thanks for the help
http://www.youtube.com/watch?v=KDh-eUhr4bw
Old Aug 1, 2008 | 08:07 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: the bird still isnt running(got a video)
Have you checked fuel pressure?..at the back of the intake is a port for testing the fuel pressure.Put a gauge on it, turn the key on and see what the reading is?..then watch the pressure and see if it drops rapidly or stays steady.If it stays steady its a good sign.It shouldnt drop but a few lbs in 20 minutes if it drops below 20 LBS in less then 20 mintues you have a problem in the system...(pump,fuel regulator,injectors leaking).I would start there..Your going to have to run some tests and post them.Sounds like a weak pump..just barely enough pressure to almost start it but not quite.Thats my two cents..
Old Aug 1, 2008 | 09:33 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Check your ignition module, theyll get you every time, if you change it make sure to grease it up before you put it in or it will burn up fast. I dont know where King George is but I am coming to Sandston, VA the week after labor day, if your still having problems I'd be happy to help.
Old Aug 3, 2008 | 08:43 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
ok thanks and someone on another board said it could be the oil pressure senders were are those located at
Old Aug 3, 2008 | 09:05 PM
jstrdn90rs's Avatar
right near the oil filter cant miss it..
Vintageracer
Jan 10, 2020 05:33 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Catcher55
Aug 15, 2015 07:08 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
3rdgenparts
Aug 6, 2015 09:03 AM
