Please help me with this... Car running crazy and I'm very frustrated...!
Old Aug 4, 2008 | 05:46 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Car: 1986 2.8L V6
Manual
I hope someone out there can throw out a possible solution to this...
To begin with, the problem started when my car sat out in some heavy rain for hours in these Florida thunderstorms... I've got a Formula hood (I think that's what it's called) with the offset scoop and nothing there to protect it from water leaking down inside. Always something I planned on making but never did... Now I completely regret that.
Anyway,
So I got in and was going down the road on this same rainy day after it and it's going crazy. My volt meter is jumping around and my lights are getting dim - bright - dim - bright... RPMs are all over, never over 2000 but dropping very low at the same time the lights dim and jumping back up and over and over and over. The car feels like its a low rider on hydrolics when I give it gas, it bounces and bucks and is just all over, giving me whiplash....
I thought it must be the voltage regulator since I've shorted that out before and the car acted the same way. I pulled over and my dad came to see what was goin on... After letting it dry itself off from the engine heat and all, we started it and it started right up and I drove it home pretty much problem-free.
It's been about 2 weeks since then and now when I drive or just sit in traffic, the RPMs are ALL OVER... but my voltage meter doesn't go all erratic like it was, making me think it ISN'T a short in the voltage regulator this time...
My dad thinks it's the injectors (originals) or just the cold start injector.
I see how the symptoms could match but the fact that this started after the engine getting very wet just doesn't seem like injectors...
I've been thrown a code 33,34, and 45.
MAF
MAF
and rich exhaust.
One MAJOR MAJOR thing I think that I should mention... When I do get thrown a SES light...because it doesn't come on all the time... The problems just seem to stop! Not completely, but for the most part, it doesn't stumble at idle hardly at all, it runs without bucking me out of my seat, but with the light off, I'd just rather not drive it
I cleaned out the MAF with some cleaner bought from Advance Auto...
I plan on driving it tonight with the MAF unplugged to see if it does any better...Maybe somehow it shorted out with all the water.
My distributor is right where all the water drips down.... I know, I know...kick me... So maybe it has something to do with that???
If I throw the car into nuetral, it will stumble and die...but start up immediatly.
I've been looking for vaccuum leaks but haven't found any so far...
I have an air/fuel ratio gauge hooked up and it's just all over the place when the car is running...
Any ideas or opinions on what to look for next?? Anything is helpful!
Thanks guys
Old Aug 4, 2008 | 08:43 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
Re: Please help me with this... Car running crazy and I'm very frustrated...!
i know its not reccomended but ive been driving with out a maf for a year now and my car has been running fine its alittle rich but i havent had any problems so far. If anyone has a spare one lying around or knows of a place that sells them cheap shoot me a pm.
Old Aug 4, 2008 | 10:46 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
all that water running over the distributor.. is it cracked.. or not sealed correctly id check that first... wires making good contact?
moisture in a distributor will make any car run like crap
Old Aug 5, 2008 | 09:34 AM
startercar's Avatar
Yeah I mean...I was spraying my engine and doing one of those degreaser things on my Camry awhile ago, accidentally got the distributor a little wet, car ran like crap and wanted to stall until it all dried off...took a few hours. Sounds like yours should be dried off by now though..
Old Aug 5, 2008 | 02:19 PM
Car: 86 Firebird
Engine: 2.8 V6
Yeah, my dad mentioned yesterday that the dist. might be cracked. We'll have to pull off the cap and check it out...
I drove it for about 14 miles yesterday with the MAF unplugged and it ran just like it did before it got all wet, so I think maybe that's the problem. I'll plug it back in and see what happens... My guess is that it goes all crazy again and if it does, I'll check out buying a new one.
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
matthew911
Aug 12, 2015 09:38 AM
Kaweh
Aug 9, 2015 02:54 PM
Thaney9
Aug 7, 2015 08:25 PM
