I thought it was all over for my Bird
Car: 88 Camaro
Engine: 5.7 350ci TBI L98
Transmission: 700R4 STB-T56
Axle/Gears: 2.73 STB-3.73
Re: I thought it was all over for my Bird
Man this thing is wild. It would give me a good laugh to see it goin down the road. Not in a bad way of course. Just a very artistic approach you see going on there that you don't normally see. Love that rear tach to. Nice craftsmanship. I like it!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 1988 Iroc/ 84 Z28
Engine: 383 TPI/ 5.0 H.0.
Axle/Gears: Strange 3.73/ stock 3.73
I just bought an 84 Z that had the fuzions on it. Surprisingly theyre not bad, even in the snow. One question though... whats the point of the tach in the back?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Id buy more or again.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
TomP does it again.
I got to check out his suggestion in another post about those squeeze on quick connects that comes with tach's and how he said his was cut in two by one after a while.
Went and checked and I only had 4 strands of wire left, cut spliced and repaired, started right up.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Had some funny smells, thought maybe exhaust was leakiing and getting sucked in somewhere. noticed some drips on the front frame, was oily gas. Turned on the FP and there was a very slow drip going. Traced it up top to just under the brake line loops. [real easy access, not] Just a tiny hint of a leak, the act of just taking the two clamps off that hold them down broke it in half.
That whole section right under there looks nasty while the rest is ok looking, why I never noticed, its hidden under wire bundles and brake stuff. Which also holds moisture.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thankx
Tip for everyone, drain your tank when working with fuel lines, even with the nose up higher then the tank, the gas keeps coming out, tried blowing it back into the tank with an air hose, can hear it bubble in the tank but it flows right back out both lines.
stock sizes are
3/8 feed
5/16 return
stock sizes are
3/8 feed
5/16 return
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well that was work, and don't ya know it, now the weather has cooled off.
But its good to crawl under the car and get familar with things ever so often.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
parking it early for the 3rd yr in a row.
1 ccp solinode
2 then coil wire for tach
3 this time i fed up my back n right leg.
gonna miss $20 fillin up half a tank n driving all over.
back to $20 a 1/4 tank v8 coughin as i pass every station.
1 ccp solinode
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Quick connects strike again. That’s what they give you with a fuel pump kit.
Messed up my spark years later using them, and now my fuel pump.
Scary part is I dunno why it didn’t explode.
I had to literally cut back the power wire a good inch to find metal.
The wire had burned or melted back. And the juice was either flowing through the fuel jumping the gap or arching the gap.
Now Im stuck to where if it does work fine once back in, do I trust it?
Or put in a new pump anyways. Or buy a cheap $40 pump and just carry it around.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
The exploding thing is kind of a myth. You definitely do have the ability to catch fire and then slowly burn the whole car up, though.
To make it blow up you need dynamite or C4.
Anyway, I think since you have the fuel pump out, you should take your time and solder and shrink tube the wiring to the sending unit.
I also think you should put the Turbo T/A or Grand National pump in it (also listed as the Vortec pump from the late 90's pickups with the 350). There's no doubt that the pump took a hit from the low voltage/high amperage condition of having that connection starting to burn.
Good luck man!
Good luck man!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Lets time line run this down again.
One day my brakes went to shiet, hard pedal with no stopping power unless I lean on them hard. [I do member the rear locking up once]
Folks suggested it was the MC and the fluid in it was nasty.
So while changing the MC,
I warrantee and exchanged my calipers and brake pads as I could.
I also put on a new set of rotors. [drilled and slotted]
No change in operation.
Other suggestion that the nasty fluid in old MC messed up the prop valve.
Prop valve has been changed with no change in brakes.
Last part left was the brake booster, changed it today and no change.
Changed rubber lines today also just incase I had a funny internal blockage that can happen with them.
Still no change.
Have run near a whole gallon of fluid through no problem bleeding them and no change.
Every part of the brake system is "new" all except hard lines, which I have no clue how they could be the problem.
Tossing money and parts at it has gone no where, now what???
Still no change.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
have you even verified that the booster is getting and holding proper vacuum from the engine? sounds like you have no pressure assist to the brakes, since that will cause the pedal to be hard and make it very hard to get the car to stop without standing on the brakes.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Of course, vacuum from plenum will suck your finger off.
boosters n vavle is new.
Car: 87' Firebird Formula
Here's a right side, engine on stand hiding some rough spots in the rear, still gonng get rear glass wide body fenders so I don't want to spend allot on fixing it. Also the car is all dull, if you look at the hatch in my sig and the pic you can see. To much rain latley washes it clean n makes the primer parts look real dull.
Few mins of work and a can of magic spray make the whole car nice n shiny like sig pic.
Mann, i saw this on google
images last night while searching for exterior ideas for my 91. I was like.."OMGGGG this is AWESOOOOME!!!" sooo, i am now going to use your car as a template for some ideas of mine. LOVE the notchback/vent combo too
Id love to "borrow" that idea lol
but im sure its not as easy as seen in the pictures
And that hood blends in well. its not overpowering the body at all. Do you plan on doing any other mods? Love the matte black color by the way
Engine: 2.8/TBI/TPI
Did you get the brakes fixed or is it up for the winter early now?
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I had the same thing happen to me in my cutlass ....even went and bought a vacuum canister to add to the breake booster ....when I took it apart ..I noticed the check valve on the booster was cracked and the rubber garment was worn ...so went and bought new check valve and garment ....everything was good after that ....
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well you know IM back at it again this year
https://www.thirdgen.org/forums/brak...orgetting.html
amazing how I can put her away and running wise, she is always ready to go at 225,000 miles. With gas going nuts it will be the main ride for a while. Have to do more miles but im already showing 23.3MPG right out of the gate so far.
Soon as the weather clears up for more then a day, Im gonna go at the rear wheel arches with a flap wheel and start replacing metal, little fiberglass work then new paint.
hoping I can find a good left door in between.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Never had a washer resivor and of course stock washer motor was fried out.
Stole the small washer resivor from a S15 which has a motor installed in the bottom. Found a nice place to tuck it in and bolt it to the fender.
clean windows any time I want, only 13 years later
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Had a funny problem today, front left driving/parking light isn't working, which makes the left turn signals not blink.
when lights are on, left arrow on dash stays lite up, bulbs are fine, even switched em right to left to test, left will still "blink" if I do it by hand, only a 2 prong blinker is used so its not it, right blinks as normal. not a fuse....
Also working on the heater hoses, those section of metal between on the frame rail was rusted through. Cold snap showd up n I need heat now too
Car: 1986 Firebird
Engine: 2.8 V6
Rust strikes again
I got rid of mine many many years ago (1996 actually), a few years ago I changed those hoses to the braided steel ones, used these Made4You clamps to hold them together by the exhaust http://www.summitracing.com/search/B...ounting-Clamps
I got rid of mine many many years ago (1996 actually), a few years ago I changed those hoses to the braided steel ones, used these Made4You clamps to hold them together by the exhaust http://www.summitracing.com/search/B...ounting-Clamps Joined: Sep 2004
Engine: 2.8/TBI/TPI
Its usually a ground problem for me when it does that. The front lights are not grounded properly and the light sockets do get worn out. If you don't have high enough amperage running through the circuit it won't make the turn signal flasher hot enough to trip and flash.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Rust strikes again
I got rid of mine many many years ago (1996 actually), a few years ago I changed those hoses to the braided steel ones, used these Made4You clamps to hold them together by the exhaust http://www.summitracing.com/search/B...ounting-Clampsnice having a spare "car" with lots of the same parts.
next on my brake job if all new parts again didn't fix it, was to swap the brake system off it.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well there is the right way and my way. The right way wasn’t getting me anywhere so….
I cut the brown wire for the left front parking lamp, which then lets all 4 turn signals and flashers work as normal, no more arrow on the dash, but no power to left front parking lamp. 30” piece of wire from the brown wire for the right front parking lamp, run over to the left front parking lamp socket….
Walla, now all lights, light up and flash as expected.
Also did a little gold-bondo work n hole repair, more for vanity sake as I still want those wide body rear fenders and the area Im fixing is cut out when those are installed.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
my way worked for about a day then it came back, and was a lose ground at the socket but also a bad bulb in the rear that I guess worked against me at first and why I could get anywhere the first time around. After a bumpy ride the rear bulb finally burnt out and revealed itself, wiring is all back to stock.
gonna spend a few bucks and replace all my bulbs as its time to wet sand and re-clear the taillights again, that 99cent walmart clear only lasted 7-8 years
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I am more and more confident about my brakes and I have to say the best part of all was a set of $10 copper metallic pads from autozone. The super fancy $70 lifetime warranty ones I had sucked, no bite at all and showed very little wear, new pads went in with little work.
Forget the fancy pads people. Probably was the first mistake many years ago, same set of pad I bought when things first went bad. Also that odd noise that sounded like a metal rod draggin on the ground went away when coasting, guessing those fancy pads were so full of "hard" metal the pads light drag on the rotors did that, also why it didn't stop well, it really did have no braking power like when a set of pads wear down till its just metal to metal.
Had some fun tonight too and stretched her legs out, kinda, most can tell the car is a sike out kinda, looks faster then it is, kinda nice when folks give me room to get by, drop a gear n lose the pack on the eway. They don't even wanna try
some reason when Im in the station wagon that never happens, they always want to race. Needless to say its the wrong move
[why do people think their SUV is fast???]
was quiet pleased though, I didn't get any odd tire vibration till around 85-90 as I mounted all 4 tires myself and haven't had them balanced yet
two fronts went on by hand, so new and soft I didn't need a pry bar, running 205/70/15s front, 225/60/15 rear, fronts are only a hard nipple taller and they have that classic fat sidewall look, gonna duplicate it in the rear but need a wider rim then stock, but a 10in rim is to wide. Rim needs to be as wide as tread block width or a hair wider to achieve that look.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
wish I could hold and look at one of these to see how I could mount it as a replacement air dam with two fog light ports.
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=78
Part # 29-9832 AIR DEFLECTOR-BLACK PLASTIC
width is right, my S15 has the more square one up top.
I wanna get some amber fog lamps up front, but don't want them to hang from under the nose, done that before, want more molded in, only option up front would be a custom license plate bracket and have them rally style
two side by side in the center.
two side by side in the center. Last edited by Gumby; Mar 31, 2012 at 01:58 AM.
Engine: 2.8/TBI/TPI
...running 205/70/15s front, 225/60/15 rear, fronts are only a hard nipple taller and they have that classic fat sidewall look, gonna duplicate it in the rear but need a wider rim then stock, but a 10in rim is to wide. Rim needs to be as wide as tread block width or a hair wider to achieve that look.
Have you ever run the 235/60-15 on your rims? We started running them back when we lived down in Van Wert and never went back to the skinny stuff.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
get some Alston SFC, wih no body roll I can make 90* turns at speed and only thing that happens is I get tossed out of my seat
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
While putting the rubber S15 heater hoses on there I noticed the starter wires / fuseable links were touching the exaust, and probably for its whole life and only a tiny spot sort of melted on one of the link covers.
but anyways I went through the hello of wrapping that section of exhaust with header wrap plus a tin shield from the top.
Then got the rubber hoses put on and tucked away with their own tin shield for the small section that gets close, had a piece left and put a tin shield on the new brass prop valve since its close on the other side.
So now I got heat if I need it just in time for summer
pretty dead set on painting it matte black in the next week or so. wait for a string of decent days and do it one section at a time since it will be outdoors like I paint all my cars. [can legaly do 3 a yr with no booth per EPA]
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
There were two plastic blocks bolted to the frame just in front of the rad support, no idea what they are or were for, but they made a great place to mount the fog lights. Putting them back under the nose sort of hidden but still below yet up out of the way. [no curb grind]
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
^ ahhh those worked out well, I can see a good full lane width plus beyond the edge of the road, lights up turns well.. back under the nose some was the ticket.
Engine: 2.8/TBI/TPI
Nice tip.
I see my V6 bird getting a similar setup in the future. Nice job!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Odd how little paint it takes to re-paint a car when the base is fine.[just dull]
bought a gallon, lucky if I used half a quart and Ive done the notch, rear bumper, R door, both front fender and the nose.
I did it that way so I could do a small section at a time, also I was able to use my mini 4oz detail gun that worked great, wasn't no worries about over spray like if I got out the big HVLP [but no way the mini will do for the main body section, roof and hood]
http://www.harborfreight.com/air-too...gun-92126.html
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
always consider road vibrations, two items don't have to touch, just be close.
FI fuel lines right there next to the resivor, have bumped and rubbed a hole into it ahh-boot half way down the tank.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oh just braggin, one of them newer hopped up forign cars that looks like it has a 20K body kit factory, Im like this guy is nuts ridin my bumper in the turn lane, I was only doing 30 in 3rd when I pulled onto the eway ramp and just stuffed it to the floor, and steadily pulled away, speedo was burried deep when I noticed them give up and fade back.
230,000+ miles, 13 years of my ownership, still making me smile at will, thats why GM is #1.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Another one of my years old ideas is gonna happen ???
I need to remove the center section, sand and repaint it, along with polishing the yellow off the plastic on the tach.
Gonna finally attempt to add a gear indicator light with the tach.
http://www.ebay.com/itm/120925949671...84.m1438.l2649
Will just use this cheap indicator made for motorcycles, has 5 speeds and N, just no R, but maybe later I can build or re program one to make an R.
the car ones cost way to much and are just for autos [not even close]
no clue yet how im gonna make it work, my old idea was always to use a ground activated system, maybe if I can find a T5 pattern shift plate with slots, use rubber fingers on micro flip switches for the gear slots???
maybe use a relay of sort so N is always on, unless in a gear.
bright white back up lights probably make seeing R a mute point.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Since rockauto was giving them away, I got a new center link and idler arm for now...
Good idea. Depending on the condition of the rest of the steering - its a lot less labor intensive to replace the entire steering system since it pretty much unbolts with 5 bolts or so - no need to separate anything since the new steering parts go together cleanly. Also - I think the center link is probably the most costly part of it all. When I did my Cutlass it was around $300 for all Moog steering parts :O
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
tie rods ends and the ball joints are like new tight, only slop I can find is in the center link parts n idler arm.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well beised not having a 18mm, even though I got 900 sockets n wrenches of all the other sizes it went ok. Idler arm bolts were PITA though.
All the slop is gone, I haven't fully tested it yet, around town is fine. Yet to go on the eway.
Got my gear indicator light today
Dunno why I didn't see it, but now that I have the thing it is ground activated.
Making it 100% easier with my original idea.
make a plastic plate with lead blocks, ill weld a point onto the shifter fore n aft, wire for each gear will run to a block, that is ground isolated, until I put it into gear and the metal point stabs the lead, grounding the lead for said gear through the tranny, simple........
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I left a guy dumb founded tonight, he was loading up his van at walmart while his family waited to leave.
I pulled up and the guy stopped mid loading and just stared like he saw a naked lady. When I got out, he was still staring, gave me a quick eye glance then back to the car. I got all the way to the door and the guy is still there motionless looking at it. But now the kids have their heads poked out to see what up with dad.
Im sure he took a cell pic, either to make fun of it or to share it. I have gone well out of my way to make it my own, none other like it. Not always everyone taste.
Still enjoyed it.
Still enjoyed it.
( I tried to help with your brakes message)
