rebuild kits??
Old Aug 11, 2008 | 12:00 AM
sloviks88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
rebuild kits??
where can i get a rebuild kit for the 2.8l jus top end
Old Aug 11, 2008 | 01:55 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: rebuild kits??
I assume you're including the heads in 'just top-end'.
Take the heads to your local machine shop and get the works.
Buy an intake gasket kit from your local parts store.
Have someone media blast your intake pieces.
This is a good time to port/polish your intake.
Check your pushrods for any gunk buildup inside them. A pressure washer with a very small fitting and an air compressor to remove the remaining water will work well. Or you can just buy new pushrods. Verify the pushrods are straight by rolling each one on a table with your hand that is known to be flat(check it with a straightedge first).
Clean your valve covers. Media blaster would be good.
While you're there, could always have the intake and valve covers powdercoated or painted. It sucks rebuilding something and no one knowing the difference when you're done.
Old Aug 11, 2008 | 02:03 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: rebuild kits??
you can get all of the gaskets from carquest. I got mine w/o head gaskets for around $50.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tonys91rs
Oct 10, 2015 03:31 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
