rear end question
Old Aug 24, 2008 | 05:19 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
rear end question
I recently purchased a 89 camaro V8 car for parts and I was wondering if I could swap out the rear ends and if that RE would be any beter than my v6?
Old Aug 24, 2008 | 06:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: rear end question
Not really as the v6 has better gears in it.
Unless your going to big power V8
Old Aug 24, 2008 | 06:47 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
depends what rear is in the 89? is it a 9bolt bw, or a 10bolt gm....if its the 9 then it is stronger stock vs stock....
Old Aug 24, 2008 | 07:46 PM
micali's Avatar
Engine: 2.8
I thought about swapping the motor out at sometime with a v8. So is 9bolt or 10 bolt better? Would the v6 RE hold up to a mild v8?
Old Aug 24, 2008 | 07:50 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
the v8 and v6 have the same rear ends just v6 typicaly have better gearing...the 10 bolt in our cars are pretty weak the 9 bolt is a good bit stronger stock vs stock but the 9 bolt is lil rare...look at the cover mounting bolts if it has only 9 then it is a borg warner 9 bolt. you probably have 10 bolt rears in both cars so in that case dont worry about swapping cause neither is stronger then the other...
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
