Need info on V-6 2.8L
Old Sep 23, 2008 | 01:26 AM
aig90's Avatar
Replaced the heads on an 89 RS but , now stuck on putting all the components back. Any info on pics or diagrams would be appreciated
Old Sep 23, 2008 | 10:14 AM
Z89firebird2.8Z's Avatar
Re: Need info on V-6 2.8L
Try picking up a Haines manual at your local parts store, I have one for my firebird, and it has several pics etc. that may help you, also if you have any more specific questions let me know, I have the exact same motor in mine I'll see if I can help.
Old Sep 23, 2008 | 11:37 AM
Sorry spelled it wrong, Haynes manual oops
Old Sep 23, 2008 | 06:41 PM
aig90's Avatar
I have a Chilton's manual the pics are mostly for V-8's and older V-6's. If there is any way you send a picture of your engine I would appreciate it. We are stuck on the position of the bolts on the exhaust manifold.
Old Sep 25, 2008 | 08:21 AM
I can definately help you with that, I'm installing headers right now, so I have those bolts pulled out. Are you keeping the stock A.I.R. system on your car? I'll also see what I can do about getting you a picture from before I took it all apart.
Old Sep 25, 2008 | 06:03 PM
badpontiac's Avatar
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
a tip for future prodjects masking tape and a sharpe lable everything then after youve had the motor apart as much as me and evryone else have had you wont need it anymore
i didnt meen that to sound like i was being a jerk its just some advice sorry if i sounded meen.
Last edited by badpontiac; Sep 25, 2008 at 06:04 PM. Reason: Automerged Doublepost
Old Sep 26, 2008 | 05:51 PM
I do the same thing, good old masking tape.
Old Sep 26, 2008 | 06:16 PM
badpontiac's Avatar
Engine: 2.8l v-6
Axle/Gears: stock
cant beat it saves alot of cigarets wile you play one of these bolts is not like the other one
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
bplessy
Sep 30, 2015 12:14 PM
