1991 Firebird stalls
Old Sep 27, 2008 | 02:53 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
I am posting this for a friend.
"My car is still acting up. Dropping RPMs acting like it's going to stall when the pedal is in a certain position. It's the same position every time, and I can make it do it. If I accelerate from a stop only to get up to about 15mph, it stalls. I tried pumping the gas pedal, but it doesn't work. If I accellerate from a stop to get up to about 40mph it acts like it's going to stall - the RPMs drop and speed drops, but if I just hold my foot there it will eventually correct itself in a few seconds. Sometimes I have to pump the gas to get it to accelerate again. At higher speeds like 70 on the highway I have to pump the gas hard and a lot"
Thought it was her tps but I tested it and there are no dead spots. She has replaced one injector a year ago because it was bad. There is no check engine light. I am thinking this may be a fuel related issue. Any help would be great.
Old Sep 28, 2008 | 10:45 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: 1991 Firebird stalls
first off what size of engine? whats the fuel pressure at idle?
Old Oct 2, 2008 | 11:27 AM
Sorry for the long delay.
Engine is the 3.1 liter.
Fuel Pressure at idle is 38psi
It pulled 42 psi getting up to speed driving
And it pulled 46ish psi when the vehicle was stomped on.
The fuel pressure seams fine to mw with a vacuumed refrenced FPR
The TPS is not the prob, I checked it out slowly going from closed throttle to WOT with my DVOM, 0.4v at closed and 4.92 at WOT. Seems good to me.
jhawkeye
May 25, 2022 06:33 PM
evan555222
Sep 20, 2016 02:51 AM
deracer
Apr 11, 2016 12:04 AM
wild1
Aug 27, 2015 09:01 AM
evan555222
Aug 22, 2015 07:14 PM
