90* V6 Camaro
Old Sep 28, 2008 | 10:36 PM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
90* V6 Camaro
Has anyone on here done a 4.3 swap?
Old Sep 29, 2008 | 11:07 AM
Transmission: WC T5
Re: 90* V6 Camaro
nobody,.. awsome looks like i get the first shot
Old Sep 29, 2008 | 11:59 AM
project89's Avatar
Re: 90* V6 Camaro
dont waste ur time
#1 the only 4.3 worth doing the swap with is a vortec and even then u cant keep the fuel injection the vortec motor has that dumb spider injector
unless u do a full ecm swap
#2 its the same exact amount of work to swap in a small block
u need a v8 transmission and front springs though with a 4.3 u may get away with the v6 front springs
#3 if u want to turbo or supercharge the 4.3 u will run into issues around the 400hp mark or so seems mostly what ive read and heard.seems after 400 hp u need to spend a decent bit of money beefing everything up.
if ur looking for that and u planed on turbo ir supercharging stick with the 2.8/3.1 that u got now
#4 the 4.3 and v8 get about the same gas milage
Old Sep 29, 2008 | 03:54 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: 90* V6 Camaro
There have been people that have talked about it, but I dont think that very many (if any) people have done it. I would search the engine swap section...there might be more info there.
If you do go through with it, keep us posted. Ive always wondered about this swap...and I love pictures of engine swaps
Old Sep 29, 2008 | 06:38 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: 90* V6 Camaro
u got a 305, so a 4.3 wouldn't be too big of a project, but the spider injection thing that project 89 was talking about is kind of a hurtle. I say go bigger rather than smaller, a nice junkyard 350 would be good or a 327 would be ****ing awesome. why do you want a 4.3? I admit its kinda interesting to think about.
Old Sep 30, 2008 | 09:36 AM
SBC383's Avatar
Car: '84 Firebird
Transmission: 5 spd
Re: 90* V6 Camaro
Did the 4.3 swap a few years ago. Very easy to do. I had a '95 TBI 4.3 from a full size p/u with the harness and computer. Use v-8 mtr mounts in the V-8 location. You've already got a 90* transmission and the location doesn't change. I used Edel headers for an Astro van. Drivers side fit fine, but had to bring the psngr side closer to the block so that the collector would clear the sub-frame (no AC). Had to fab a y-pipe as I was using a Lakewood shield that is considerably larger than the stocker. Otherwise the y-pipe from the header kit would have worked (with a tweak or two). I used V-8 suspension and sways because it was past time to replace anyway and already had subframe conns and a strut tower bar (carb type) installed.
The car handled really well, no lean or plow, but a stock 4.3 isn't known for big power. Had to work the gears (5 spd) a lot to make it fun (which was part of the fun!), but I never got to the centrifugal or turbo stage......next time.
