testing egr for failure??
Old Oct 25, 2008 | 02:05 PM
frankieboy89's Avatar
Car: 89 rs
Engine: 2.8
hey guys i jus pulled a 32 code from my 89 2.8, which i was told is egr failure...was wondering if anyone knows any way i can test the egr, and what to test for in order to find out exactly what from the egr is faulty?? if anyone could help me out i would appreciate...thanks
Old Oct 25, 2008 | 02:31 PM
91SpeedCam's Avatar
Re: testing egr for failure??
Does your car have a diaphragm on top of the egr vavle or is it a digital egr.
I feel your pain cause I'm working on my EGR at this very moment
Old Oct 25, 2008 | 11:46 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
could be as simple as a loose vacuum hose.. id check those. or the ports could be blocked with carbon buildup.
Old Oct 26, 2008 | 12:15 AM
project89's Avatar
2.8 has the non digital egr,which even if the valve itself is bad its a cheap fix
9 out of 10 times its the soilinoid that is bad good luck finding one of those cheap,
Old Oct 26, 2008 | 01:59 PM
Car: 89 rs
Engine: 2.8
i checked the vacuum lines and one of them is not connected to anything but im not sure where it goes...its not a line comming straight from the egr its a line that comes off the thermal vacuum switch but not the one connected to the vacuum port or back to the egr...its another one that is bent back to go somewhere under and behind the egr...i checked the diaphram with car off and it does move up when i push it up, and comes back down by itself...but another funny thing is when i run the car for little while, then shut it off, the egr valve itself makes a tinging noise over and over even with car off?????...could that be the solenoid???
Old Nov 4, 2008 | 01:36 PM
pontiacguy1's Avatar
I was wondering where to get gaskets and such for a 1992 with the digital EGR? I have gone to all of the auto parts places, and when I ask for the gaskets to fix the EGR, they look at me like I just orderd a crap sandwich.
Is the dealer the only option for getting these? Mine has started leaking and will need to be repaired soon.
Old Nov 4, 2008 | 08:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Use high-temp copper RTV. The COPPER stuff (good to 700*), not RED (400), BLACK (500), or BLUE (200). Save the tube and use it for everything. When you do this, however, just barely snip the end of the tube off, you don't want a string on the small edges of that EGR valve the size of which you would use on your intake, it will clog the tiny passages in the valve.
Oh, and if you don't like that idea, ask the parts store for an EGR gasket for a 1993 Beretta, Grand Prix, Lumina, or Regal with the VIN T engine.
:edit: Did some searching, and found your gaskets. Go to the auto parts store and ask for FelPro gaskets 70208 and 70397... If you can't get them at the store, order them on partsamerica.com and have them shipped to your house.
Old Nov 5, 2008 | 10:13 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Read my posts in this thread, your procedure is the same.
https://www.thirdgen.org/forums/v6/4...egr-valve.html
Next time, please use the search function, as it was easy to find.
Old Nov 5, 2008 | 10:32 PM
Engine: 2.7L V6
Axle/Gears: 4.41
This guy has his vacuum monitor hose disconnected from the valve circuit, which is why the ECM is throwing the 32 code and his EGR isn't working. He could also have a bad valve, but let's get it to where it COULD work first.
That vac line you have that is disconnected from everything gets plugged into that box that has the 4-wire connector on it. Hopefully, now, when you plug that in, your valve will work, instead of just sucking air into the engine and setting a trouble code. Oh, and that tinging is normal, it's just the hot metal parts of the exhaust cooling off when you shut her down.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
