Injection timing for a 1990 camaro RS V6
Old Nov 1, 2008 | 04:36 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
I need the ignition timing for a 1990 camaro RS V6 3.1 with Air. My Manual said it's in the engien bay. Counldn't find it and my guessing it is on the stock hood that I don't have anyone. Help plz Yes I know that is said Injection not my fault, blame firefox.
Old Nov 1, 2008 | 04:49 PM
project89's Avatar
Re: Injection timing for a 1990 camaro RS V6
12* btdc with the est bypass wire disconcted with the motor at operating temp
Old Nov 1, 2008 | 05:19 PM
melsplace6's Avatar
My 91 says 10 degrees in nuetral and 10 in drive.
Old Nov 1, 2008 | 05:20 PM
project89's Avatar
opps i gave u the timing for a 2.8, but 12* is fine on the 3.1 as well will actually make it run a lil better uptop
Old Nov 1, 2008 | 05:22 PM
melsplace6's Avatar
cool, as long as it don't set off the anti knock sensor.
Old Nov 1, 2008 | 07:43 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Thanx guys, I'm going to set it to 10 for right now as I am haveing problems but I remember hearing that running it at 12 is better so I'll change it once I work out the bugs. Thanx again
Old Nov 1, 2008 | 08:21 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
yeah, 10* is stock for all 2.8L and 3.1L engines, but most people run at 12* or 13* for a tiny bit of power and fuel economy. I personally run 15* and hdo not have a problem with detonation.
Old Nov 1, 2008 | 08:49 PM
project89's Avatar
2.8 u sure on that, i remeber my old sticker on my stock hood saying 12* on my 2.8, but i no longer have the stock hood to look again. i will dbl check nextime in in the jy though they have a boatload of v6 f-bodys and even 2 iron duke f-bodys
everytime i go i always have to fight the urge to go ask how much for one of the iron duke cars as there all there but one has a blown motor and one has a bad trans.
could be an interesting lil turbo 4 banger project
Old Nov 1, 2008 | 10:13 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
100% sure on that. All stock 660's with adjustable timing were 10* BTDC
Old Nov 1, 2008 | 10:27 PM
project89's Avatar
prolly just so used to setting it to 12* and hearing everyone else set it to 12*
i really wish i had my old stock hood still i really coulda sworn it said 12*
Old Nov 2, 2008 | 12:56 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
this may be a dumb question but... how do you change your timing? I've never attempted it... also, won't the ecm just put it back to stock?
Old Nov 2, 2008 | 01:08 AM
project89's Avatar
u can set the base timming, so say u advance the base 2* it will always be 2 more then the ecm would normally have int he motor same if u pull it out.
u start the car and let it warm up, then u unplug the est connector and use a timing light like u would any othe rmotor and rotate the dizzy
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
