HELP!!
Car: 92 camaro rs
Engine: 3.1
HELP!!
92 camaro 3.1 auto. Car starts but idle's very rough and will only drive about 5mph. I replaced the cap, rotor, plugs, plug wires, oxygen sensor and map sensor. it's got 40lbs of fuel pressure. Checked for vacuum leaks found none. Anybody have any ideas?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: HELP!!
Check the electrical resistance of your fuel injectors, should be around 12.6 ohms per injector, 4 per bank...
Also, try cleaning your IAC motor and passages inside the throttle body and check your TPS.
