wierd idle
Old Nov 12, 2008 | 12:35 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
wierd idle
my car idles wierd while cold... goes from 1500 to 2000 ish . while warm it idles like normal 850 ish.. im thinking its the iac acting up.. got a new one already. its 1 month used. on the other engine i blew up. just gotta take the time and replace it tomarrow night.
i cleaned the passages before i installed the engine in my car. or it could be a slight vacuum leak. hah . been cold /rainy here not easy to realy troubleshoot out side.
ill have the car up on a lift friday to figure out this damn vss error im getting. im thinking its just loose connection since the trans was out for a while and i gotta check the trans fluid level.
also need to check starter bolts. starter not always engageing.. new starter about 5 months old. might have to reshim.
Old Nov 13, 2008 | 03:54 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: wierd idle
gonna pull the intake this weekend and clean it up a bit more noticed some carbon build up when installed the new iac.
Old Nov 14, 2008 | 08:01 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: wierd idle
pulled the throttle body.. hah i found half a throttle body gasket... hence source of leak for bad idle. runs much better now. cleaned throttle body and iac passage. idles like a dream now.
junior419
Apr 7, 2025 11:35 AM
mud runner
Nov 2, 2015 07:30 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
