im in the club...almost
Old Dec 7, 2008 | 05:00 PM
noXid's Avatar
I'm going to be buying an 88 v6 camaro at the end of the month...I used to have a v8 88 camaro, but it was sold a few months ago...so I have a question...how can I get back the power that I had with the v8 (and surpass it)...in a v6 engine.
discuss.
Old Dec 7, 2008 | 06:05 PM
mexicanknight's Avatar
Re: im in the club...almost
money and a lot hahah, well you could go with a hybrid 3x00 with a turbo and lot of boost
Old Dec 7, 2008 | 06:15 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
a 3.8 and cash.
Old Dec 7, 2008 | 07:52 PM
project89's Avatar
Originally Posted by ryan91rs
a 3.8 and cash.
rubish.
but u could come down to my shop in nj and buy my 3.1 turbo motor, will put ur car right into the 12 second range as is, or even faster if u swap out the small turbo
Old Dec 8, 2008 | 12:38 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
discuss.
Custom swap to a 3.6L DI V6 from a new CTS...
From now on, please do a search for this kind of thing. It has been covered MANY times.
Old Dec 8, 2008 | 11:52 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
you can get power out of anything with $$$ :-) searching will bring up loads of ideas, typically swap out the block for the rwd 3.4 from a 4th gen then use fwd heads/intake
https://www.thirdgen.org/forums/v6/4...ghlight=hybrid
have a read, keep searching and learning and youl soon get your own idea
happy cruising
Old Dec 8, 2008 | 12:50 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
i say go back to a v8, you can build v6's or swap in a new one as mentioned above but youll spend more money trying to make a v6 "surpass" a v8 when you could just get the v8 and already be a step ahead, take the $ youd save and put it into a forced induction setup (S/C or turbo)
Old Dec 8, 2008 | 04:28 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
if you have the money, do the 3.6 swap. there was a guy on here a few months back that had it done and all figured out. search for that thread. probably better milage along with easy horsepower. the CTS has DOHC so it has an advantage out of the rest of the v6 engines available.
Old Dec 8, 2008 | 04:32 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
^what hp are they running ? ^
Old Dec 8, 2008 | 06:11 PM
firstfirebird's Avatar
That depends on the v6
http://s448.photobucket.com/albums/q...t=100_4322.jpg
^^^Motor cost me about $1200 including parts and a rebuild, and have $500 or less into the turbo kit so far.
3.4/3500 hybrid motor will spank unmodded 305's, and give an LT1 a run.
Old Dec 8, 2008 | 09:35 PM
I'm not sure, but I think its around 300 HP and 270 lb-ft of torque. thats some serious power. it has direct injection, variable valve timing, DOHC, and 4 valves per cylinder. its good enough GM is putting it in the new camaro as the V6 model if that means anything. it costs some money to do, but you have the technology of a new cadillac in a neo-classic sports car.
