Am i nuts?
Old Jan 6, 2009 | 08:32 PM
  #51
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Am i nuts?
Id line them up with you after I put on a turbo system myself or a 383.
Your missing the point, again *sigh*
stock 6 vs stock 8 / 6's are 2 seconds slower GET THAT THROUGH YOUR FREAKING SKULL
Old Jan 6, 2009 | 08:43 PM
  #52
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Am i nuts?
This tread is based on stock cars, not heavily modified.
Old Jan 6, 2009 | 08:48 PM
  #53
project89's Avatar
Re: Am i nuts?
lol i only put that **** up cause u brought out the i bet it still only runs 14's
and besides the cam theres nothing special about my motor
305 cars and the 3.1 cars are not 2 seconds apart either much closer to 1 second down to around .600
Old Jan 6, 2009 | 09:08 PM
  #54
n8_camaro_92's Avatar
Re: Am i nuts?
i lucked out and got a 2.8 92 25th anneversery model for about 700 bucks with 180000 miles... it needed a bit of work and i had other things done that werent necesary along with a few probs fixed all by a mechanic and id say all together my total cost for this running car was about 3000 but about 800 was not nececary... im in the process of figurin out a cold air kit for her too
Old Jan 6, 2009 | 09:22 PM
  #55
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Am i nuts?
If your still in the same car on the threads you started, looks like you've gone deep into the motor.
The v6 is pretty different for modding like you did, but why not go with a motor that would show more gains per dollar ? like the 350?
From the pics it looks like you've dumped a few grand into that 6 cyl
Old Jan 6, 2009 | 09:49 PM
  #56
project89's Avatar
Re: Am i nuts?
still in the same car, all in total ive got about 2,700 bucks with everything.
theres really nothing special about it, its a stock bottom end granted it dosent have factory pistons but they are el cheapo stock replacements.
besdies that its got some arp goodies but nothing i would consider aftermarket perfomance wise
ive owned 12 diff 3rdgens this was my first v6 and i wanted to keep it a v6,no other real reason then that
Old Jan 6, 2009 | 10:58 PM
  #57
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Am i nuts?
Most ive done to my current engine was intake manifold, only cuz i broke the bolts off the water neck lol.
Your 6 would own my 305, when you took off the line I thought it was gonna be quicker then 13's. Is the bottom end safe for 27psi ?
Old Jan 6, 2009 | 11:10 PM
  #58
project89's Avatar
Re: Am i nuts?
yeah we had issues on those runs car still isnt tuned right car should have run mid 12's.
well noone knows supposedly the block will break at 450 hp,i dont think it will so im going for broke with it.the motor is the cheapest part of my whole build so i really could care less.
should be able to get a few 10 second passes out of it though, i still have a dual nozzle wet nitrous shot on the car 35-150 hp ill prolly jet for 35 and use it out of the hole
and im swaping to a 3.4 dohc motor this year anyway
Old Jan 6, 2009 | 11:23 PM
  #59
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Am i nuts?
Damn so your gonna shoot 27 psi and a 150 shot possibly ? Id love to see a vid of that,
Old Jan 6, 2009 | 11:24 PM
  #60
project89's Avatar
Re: Am i nuts?
ive never shot the car with nitrous while it was turbocharged, i was gonna try a 100 shot on 9 psi but i never got to do it, at 27 psi ill prolly spray it with a 35 shot just to help motivate the car out of the hole
Old Jan 7, 2009 | 12:35 AM
  #61
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Am i nuts?
Well when you get your 3.4 up give it a go since you got the replacement motor !!! If that block holds up, that would be insane.
Old Jan 7, 2009 | 12:37 AM
  #62
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: Am i nuts?
Well, you've heard a lot of rhetoric about your potential purchase. You have also given some insight into your wants. So, any items of interest?
Old Jan 7, 2009 | 06:10 AM
  #63
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: Am i nuts?
nice attempt to the back on topic... LOL
It looks like I will be on the lookout for a 88-92 (prefer 91-92) camaro with a V6 and a 5 speed. I want it in original condition and adult owned, and with those conditions I'm not going to reject it mo matter what engine it has in it.
T-tops and manual windows would be nice, but I'm not going reject a strong canditate on those factors. I would love a dark red one, but dark green is my second favorite color.
Old Jan 7, 2009 | 10:29 AM
  #64
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Am i nuts?
As for insurance, I went from a v6 hardtop to a v8 vert and my insurance only changed 20bux every 6 months for full coverage. Not bad at all.
The 6/60's are mostly known for timing chain problems. So plan on replacing that when you get the thing. The 3.1's are known for digital EGR issues which is EXPENSIVE! But then the 2.8's have maf issues(not cheap). Other then that, these things are fairly reliable. I had a 3.1 with 210k miles and was running good but just started a knock. Which ended up being an out of round bore. The intakes suck taking apart the first few times. But once you know, its easy.
As for performance. The old 3.4l/t5, cam, and mild port work, STOCK tune IMO is/was faster then my current 350. The car was bare bones and had some weight mods ontop of that. I found out later it also had 2.73 gears
My current 350, TPI, fully loaded. It will rip the hell outta some tires, but once it goes, its only so-so (but it did beat a 5.3l truck last time I drove it).
Old Jan 7, 2009 | 11:16 AM
  #65
MYZ28NH's Avatar
Car: 91 Z28 Convertible
Re: Am i nuts?
Here is exzactly what you want......This car is mint! And I'll tell you that before Christmas the asking price was $1300
http://boston.craigslist.org/gbs/cto/979573638.html
Old Jan 7, 2009 | 01:57 PM
  #66
Bruce91RS's Avatar
Re: Am i nuts?
that car on craigs list looks sweet!
  #67
Twitch RS's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: 700 R4
Re: Am i nuts?
I gave 900 for my 91 RS...it's the 3.1 automatic it has power locks and windows and hatch release, and t-tops...when I bought it the guy said it just needed a fuel pump so I got it and replaced the pump and guess what...it's still sitting in my driveway because I can't figure out what is wrong with it...I have spent hours scanning these forums and I cannot find out what is wrong with the stupid car...so my advice is get whatever but make sure you can drive it home!
Old Jan 7, 2009 | 04:57 PM
  #68
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: Am i nuts?
I have two 3.1
90 SSA I bought new - I've had one problem that I could figure out and ran out of time (It was my DD at the time). With 162K on the clock it still runs fine. I need to change out the rear freeze plugs Right now it looks like GTA...
I pickup a 92 Firebird Vert last summer.
I'm pleased with the motors
If I need a fast car I can take out the Vette
Old Jan 7, 2009 | 05:38 PM
  #69
project89's Avatar
Re: Am i nuts?
twitch saound sliek my car when i got it throw a new ignition module in it
Old Jan 7, 2009 | 05:54 PM
  #70
58mark's Avatar
Re: Am i nuts?
thanks for the link, but there's one thing about it that would keep me from getting that car, at least for the listed price... anybody know what it is?
Old Jan 7, 2009 | 07:26 PM
  #71
project89's Avatar
Re: Am i nuts?
none stock shifter and it has nitrous,(meaning the car has been meesed with)
he says theres no bottle id give a call or email maybe hes never used the spray on the car yet.
oh and u also dont like that style gauge cluster
Old Jan 7, 2009 | 07:39 PM
  #72
MYZ28NH's Avatar
Re: Am i nuts?
he says in his first post he's looking for an 88 - 92...so that's not it. Maybe it's to nice or to far away. He doesn't say where he lives. For 1300 I'd fly and drive for the right car. Maybe he wants a fixer upper......
Perhaps this more what he's looking for......
http://maine.craigslist.org/cto/982660477.html
Old Jan 7, 2009 | 07:56 PM
  #73
58mark's Avatar
Re: Am i nuts?
i like the gauge style of that year just fine...
It's the nitrous... a sure sign the car has been run hard and put away wet. I wouldn't touch that one with a ten foot pole
Old Jan 7, 2009 | 08:03 PM
  #74
58mark's Avatar
Re: Am i nuts?
yeah, i'm in texas... I dont think i could get that one home... but if it was a 5 speed and cheap, I'd consider it.
Old Jan 7, 2009 | 08:04 PM
  #75
MYZ28NH's Avatar
Re: Am i nuts?
I was just about to edit my post again saying I'm sure it's the stupid nitros. Not something I would advertise having on my car if I were trying to sell it. Probably why it didn't sell when he was only asking $1300.... Then again for 1300 it still might be worth it. Run it till it dies than put whatever motor you want in it. Good project for you to do with your kid.
Old Jan 7, 2009 | 08:18 PM
  #76
58mark's Avatar
Re: Am i nuts?
for that price... you're right, I'd buy it in a second if it was closer. Boston is a long way from dallas though.
I'm wondering why it didn't sell for $1300, but now it's $3000? something doesn't add up
Old Jan 7, 2009 | 08:34 PM
  #77
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Am i nuts?
I own both, a 1989 Firebird hardtop 2.8 5 spd, and a 1991 Firebird T-top 5.0 TBI automatic. I have to say, the amount of trouble I've had with the 2.8, it doesn't owe me anything, but I find it easier to work on the 5.0 TBI just because it's what I'm used to. But, whatever floats your boat.
Old Jan 7, 2009 | 09:42 PM
  #78
MYZ28NH's Avatar
Re: Am i nuts?
Said he was broke and needed money for Christmas and the first 1300 takes it. Said if it didn't sell by Christmas that the 1300 was off the table and he was raising his price. Well I guess he raised his price. IMO if he would sell it then he'd sell it now for 1300. However I wouldn't wait till spring.... then you'll never get it for that price.
Old Dec 13, 2009 | 12:49 PM
  #79
58mark's Avatar
Re: Am i nuts?
gonna bump an old thread here to post a thought...
I'm still looking for a good camaro to buy, and I've been looking at both 305's and v6's. I'm a do it yourself kind of guy, and the v6 just seem so much more user friendly to work on. you can touch all of the spark plugs with your hands, and there's room to get tools down in the engine bay.
I don't know how much that's talked about here, but that's a HUGE plus for me. Much more important than a marginaly faster jump off the line, or even a little improvment in MPG
Old Dec 13, 2009 | 02:25 PM
  #80
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Re: Am i nuts?
Just keep your eyes on Craigslist. You will find one. I just grabbed an '82 Berlinetta V6 for $700. Just find the one in best shape and buy it
Old Dec 13, 2009 | 02:40 PM
  #81
58mark's Avatar
Re: Am i nuts?
yeah, I have the camaro search bookedmarked for every city within 300 miles of me... just gotta wait for something to come up and jump on it
  #82
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Am i nuts?
You can get a V6 and still have a fun project. Possibly put a 3.8L in it from a late '90s f-body. You will have much better fuel economy. It would just be a lot of work.
Old Dec 13, 2009 | 03:14 PM
  #83
dealbatony's Avatar
Car: Trans Am
Engine: V8 350 TPI
Re: Am i nuts?
I had a v6 camaro n I wasn't impressed..at all..
Now I have a v8 gta n that car suprised me everyday =)
but yeah if u get a v6 it never gonna be of great alue u can completely restore it and it'll look nice but if u ever wanna sell it, chances are ur not gonna get anywhere near what u put into that car..now if you did that to a z28 or iroc-z it would be a much diffren story I've seen completely restored irocs on eBay go for 35xxx plus no lie!
Old Dec 13, 2009 | 03:25 PM
  #84
58mark's Avatar
Re: Am i nuts?
I've had a v6 camaro before. I'm not interested in speed. I'm 40 years old with a family, as long as it will get up to highway speeds, I'm happy
I'm with you about the cost/value factor. If I do this, I need to get a car that is a nice looking, good running car, or it's not worth it. I can't get a wreck and pour money into it
Old Dec 13, 2009 | 08:23 PM
  #85
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Am i nuts?
LOL, I've lined up against tbi 305's and spanked on them before, but my car's not stock either. Just the motor.
I get plenty of compliments on how it looks & sounds even with a 'raspy' 'lil v6.
Old Dec 14, 2009 | 03:55 PM
  #86
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Am i nuts?
my 3.1 that I just pulled out laughed at 305s!!
Old Dec 14, 2009 | 10:16 PM
  #87
drewman_93's Avatar
Car: 89 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42 open
Re: Am i nuts?
not to bring up a dead subject...but stock 305 tbi runs about 17 seconds...is rough trying to say that our v6s run 19? when my 0-60 is 9.8 stock? come on now....don't come into the lions den and start trouble.
timonator
Sep 30, 2015 12:52 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
aharvel50
Sep 21, 2015 07:31 PM
Fox118
Sep 12, 2015 09:29 PM
