COLD AIR INTAKE FOR A 2.8L
Old Jan 29, 2009 | 02:23 PM
vargasjc's Avatar
I am looking to get a cold air intake for my 2.8l 89 firebird...
where can I BUY one?? about how muh they $$? and whats the down side of them??
Old Jan 29, 2009 | 02:26 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: COLD AIR INTAKE FOR A 2.8L
Home Depot/Lowe's.
About $20, plus filter.
Old Jan 29, 2009 | 02:28 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Your best bet, having a Firebird, is to make one yourself out of PVC pipes or some metal pipe. But the only true cold air intake, that I am aware of, for the Firebird is the Ram-Air hood/intake box...which is a bit pricey for such a little gain.
Do a search for "cold air intake" or "CAI"....There are A LOT of people that have asked this same question.
Old Jan 29, 2009 | 03:49 PM
vargasjc's Avatar
Originally Posted by jensen73110
Home Depot/Lowe's.
what do I ask for?
Old Jan 29, 2009 | 09:04 PM
nd4spd42085's Avatar
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
Originally Posted by vargasjc
what do I ask for?
c'mon man just get creative...
all you wanna do is use some kinda piping from your throttle body to extend to where the stock air box was that flows better...
you could PVC, which is rather unattractive, but effective. Dryer ducting can also work if you use the right components, but tends to be brittle...
or you can do what I did and go to autozone and just buy the piping and the rubber fittings with the clamps... you can buy the universal stuff in different colors in different bends and shapes... I sprayed over mine with ceramic paint...
or hell, you could just use the stock intake tubing and throw a cone air filter on the end of it... sure it's got more bends then it should have and won't flow as well as straight piping, but it will flow better than the stock box....
to be completely honest though, even the stock stuff is receiving cold air, just has to jump through allot of hoops to get to your engine...
Old Jan 29, 2009 | 09:24 PM
Car: 1991 Firebird
PVC is either 3 or 4 inch diameter. You'll need at least 4 feet of straight pipe. 1 90 degree elbow and 1 45 degree. 1 container of pvc glue. 1 cone air filter. Optional spray paint.
Old Jan 29, 2009 | 10:12 PM
vargasjc's Avatar
great!!! thasnks for all the ideas...I am rady to go to home depot!!! lol
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
