TPS sensor can't go below .58mv?
Old Feb 1, 2009 | 07:11 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Yeah...I was scanning it today and I thought I'd tried to get the tps down to a minimum . Well, I got to turning the tps while looking at the scanner and I got it down to .58mv and by that time the set screw was already away from the throttle lever and not toucging it. It would seem you can get it to 0mv at least. Is the millivolt right for my throttlebody or am I missing something?
Ken
Old Feb 1, 2009 | 10:20 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Re: TPS sensor can't go below .58mv?
You mean .58 volts, not mv, right?
.58v at idle is not outside of specification for 85-89 (.55v +/- .05v), and while I can't find exact reference on the 90-92 3.1l I believe it is still within specification. You don't want 0v.
Also, the ECU reads anything over 4v as WOT, usually the sensor will produce 4.25-4.5v max
Old Feb 1, 2009 | 10:27 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Re-reading what you posted.. what set screw were you turning to adjust the TPS? It sounds like you were adjusting the minimum idle stop screw... adjusting the TPS is accomplished by loosening the two torx bolts holding the TPS onto the throttle body...
Old Feb 2, 2009 | 07:06 AM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Also shouldnt the newer 3.1 tps NOT be adjustible.
Old Feb 2, 2009 | 05:06 PM
ken3983's Avatar
You're right. Unlike the 2.8 V6, the 3.1s were non-adjustable.. I was turning the idle set screw which in turns adjusts the voltage for the tps. I guess I'm in spec., but I thought it would go a little lower.
Ken
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
